Shuttle Plus
Could someone tell me the mast size of the new Shuttle Plus. Is it 8 mm 10 mm or 12 mm
Thanks Im looking for a metal swashplate, but need to know the mast size Thanks |
RE: Shuttle Plus
I bet its 8mm but not sure , time to get out a ruler
RE: Shuttle Plus
Yes, it's 8mm. Quick UK and MTA have some good swashes for it. Basically any ZXX swash will work.
RE: Shuttle Plus
I am looking for help in settng up my shuttle. Do I mix the Collective and Throttle to run as one. And does the engine speed up with more collective and less with less collective. I use a simulater and the engine seems to stay at one speed. What do I do to set the radio JR 662 to make the engine run correctly with the pitch.
Does the engine stay constant on rpm or does it move up and down in speed with the collective. Thanks |
RE: Shuttle Plus
Have a look here for help with setting up your throttle curve: http://www.littlerotors.com/setup/throttlesettings.asp
And have a look here for pitch curves: http://www.littlerotors.com/setup/pitchsettings.asp To answer your question: the engine rpm should move up and down with the collective, unless you have the throttle hold switch activated... |
RE: Shuttle Plus
You need to find someone near you to give you a hand its too hard to do over the net, it sounds like your too new at this. Local help is really the best way to go so you will not wreck your heli needlessly.
| All times are GMT -8. The time now is 12:12 AM. |
