RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   TT 36 Engine problem please help (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/146829-tt-36-engine-problem-please-help.html)
Jet_A1 05-29-2002 12:18 AM
I have a Raptor 30 w/TT 36 engine w/ stock muffler. Coolpower 15% nitro fuel.os a3 glow plug.
the needle is open 2,5 turns
here is the problem: when I'm running the engine sometimes it starts to loose power without any reason. sometimes at full trot. I don't have enough power to get the heli out of the ground. go back to idle wait a little and try again and everything comes back to normal.
Any idea what should be the solution
Deiv.
shamoo 05-29-2002 01:56 PM
tt36
same thing happened to mine using same fuel then guess what it locked up tighter then a drum sent it in for warrenty sent back with new piston sleve and con rod second time around same thing sent it back they sent me a new motor
so i bought an os32 and put the tt in my second heli got about 4 or 5 tanks and knock on wood no problems but i put the head shim in that is the only difference GOOD LUCK
shamoo
DavidH 05-29-2002 04:18 PM
The symptons your describing are of the motor being run too lean. You run the motor at half to full throttle and after a few minutes the motor heats up and starts to lose power because it is not getting lubrication. Then you land and let the motor idle, the motor starts cooling and then it is Ok till youi give it power again and start the process all over. I would think your about 1/4 to 1/2 turn too lean on the main needle. I have helped several using the TT 36 with many different kinds of fuel and this seem to be the case on most of them.
David
rhd-RCU 05-29-2002 05:15 PM
Hi,
That sounds like good advice to me. I was thinking the same.
