RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   concept 30 tail problem (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/15729-concept-30-tail-problem.html)
mikle 04-07-2003 05:11 PM
i just put $200.00 into this heli in an atempt fly it but i resently learnd that the TAIL DRIVE COUPLING was striped and i need a new one but i cant find the part for the dx modle anywher i did however find it for the sr modle if this will work on both please say so or if you now a easy way of seting up the picth with a 4 channel remote. thanx mike
blvdbuzzard 04-07-2003 10:05 PM
I think they are the same. The tail was pretty much the same on all of the concepts as I have been told.
The other part of your message about an easy way to set up the pitch with a 4 channel, that does not really happen. The easyest way is to get a heli radio or a radio that will do both heli and fixed wing aircraft. The pitch and throttle can be setup with a "Y" cable and then you will need to adjust the linkage from servo to carb and servo to mixing base. It can take days to get it right with a 4 channel radio. Or you can set it up with a newer radio in about 15 minutes.
Dru.
