Mixing Problems
Hey guys,
I recently purchased a Quick 30 pro Helicopter and am having trouble setting it up to my Futaba T6XHS. The helicopter is ccpm controlled and I can't seem to get the pitch and elevator actions correct. For example when I properly set up every servo to the correct throw, either the elevator servo is reversed or the pitch is reversed. I have tried to reverse the servos on the radio, but in doing so I reverse the pitch. It seems as if God doesn’t want this bird to fly! If I get the pitch correct the elevators forward and backward motions are the opposite of what they should be. One time I got the pitch and elevator motions correct, but the avions were reversed to the desired position. If only I could reverse the stick on the radio. It would be of great help if you guys could help me out on this one. Thanks, Edwardo |
RE: Mixing Problems
I don't think that radio will do ccpm, check it out.
http://www.futaba-rc.com/faq/faq-6xsuper-q557.html |
RE: Mixing Problems
That radio will do CCPM.
If you have the manual then first step is to make sure all servos are plugged in the correct receiver outputs. Aileron -1 Elevator-2 Pitch-6 Set the correct swash type. Set the servo reverse switches so that with positive pitch you get all three servos moving up. Now the trick! There should be a swash mix reverse in the swashplate menu. This should correct your problem. (I was going to give you a step by step but my pc won't dispaly the Futaba download properly) |
RE: Mixing Problems
That did it, thanks a lot guys. Man I have been working on this problem forever!! Well God probably wanted this bird to fly after all.
| All times are GMT -8. The time now is 11:50 AM. |
