please delete
please delete
please delete
loops in normal... sure...
rolls in normal at -1, you'll end up with corkscrew or worse. |
please delete
rolls in normal at -1, you'll end up with corkscrew or worse. Don't forget that @ -1 you also have no throttle. :eek: Better off not trying rolls in normal. |
Re: Rolls & Loops in Normal Mode
Originally posted by Marty What should I be looking out for and what would be good technique for basic loops and rolls in Normal mode. That is, having only -1 degree pitch available? I have not setup 3D pitch or idle ups because I like the varying sound of throttle and rotor rpm over the constant screach/drone of constant headspeed. The way I'm flying it looks and sounds more like a real heli and am enjoying my Raptor 50 in this manner. I know I'll need the constant headspeed for for more serious 3D maneuvering but it seems to me this is unnecessary for simple loops and rolls? :confused: "rpm over the constant screech/drone of constant head-speed" Constant head-speed is what you want to have irregardless of idle up mode or normal modes. For doing any aerobatics you need to maintain a constant head speed otherwise you won't have enough head-speed to complete a maneuver. |
please delete
Marty,
You might get away with that setup to do a loop but I wouldn't chance a roll like that. For rolls I'd suggest that you have about -5 deg in idle up with constant head speed over the entire pitch range. I was doing some loops this weekend with a buddies Venture in normal mode but had pretty good forward speed before trying it. |
please delete
Ok, that answers that. I'll have to go ahead and setup the Raptor for the 3D throws and redo the radio for idle1. Thanks.
please delete
I would strongly advise you not to set up an "Idle Up 1" with -5, and then an "Idle Up 2" with +/-10. There is no good reason to do this "intermediate" setup, and it could well cost you a crash when you find yourself low, inverted, and with insufficient power/neg. pitch to save it (don't ask how I know this). Do it right the first time with a single Idle Up mode and normal mode. You'll always have inverted power when you need it and you won't have to learn the feel of two idle ups. My $.02
please delete
I would be very cautious about trying aerobatics without idle up. In helis rotor speed is life. If you get the rotor RPM's too low you are asking for trouble. If the constant motor whine annoys you think how annoyed you would be if you had to buy a whole new heli.
As for pitch curves between Idle up 1 and normal I think that normal should be about +10 to -3 with hover at half stick or just above. Idle up 1 should be +10 to -10 again with 0 at mid stick. There's really no need for idle up 2. I never use my idle up 2 setting. Once you get use to starting up, hover, approach and landing in normal and everything else in Idle up 1 you'll be better off. You can do anything you want with a pitch range of +/-10. Trying to roll with only -1 of pitch is scary and just plain dnagerous. If you don't have enough altitude you'll end up drilling the machine into the ground and you'll have one hlee of a big corkscrew on the way down. Get that pitch range in there and keep the rotor speed up! Also consider why a lot of heli flyers get a govenor.......to maintain a constant rotor RPM thoughout the ENTIRE flight. Full size helis always try to acheive this goal as well; constant rotor RPM. If you're chasing the RPM's all over the place then it's a disaster waiting to happen. Constant rotor RPM will make your heli fly smoother and fly through the manuvers like it's supposed to. If you even consider getting into inverted or 3D style flying you need to have it. just my opinion....... HTH, Jeff |
| All times are GMT -8. The time now is 03:54 AM. |
