RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Thread lock (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/1913259-thread-lock.html)
mustafa_m 06-18-2004 06:50 AM
Thread lock
Hi! guys someone pl help me.. by mistake i got some cayno (fast setting glue) into my flybar sesaww (its metal) threads now i cant screw the bolt in.... i tried to remove the cyno using a pointed instrument but it dosent seem to come out..........
mustafa
DarkStaR6 06-18-2004 06:53 AM
RE: Thread lock
Soak it in hot soapy water for a while & its will work loose. Try screwing the bolt in & out while submerged in the water.
Raydee 06-18-2004 07:45 AM
RE: Thread lock
If it CA glue you used you can also use acetone on it to soften it up. They sell CA remover in the hobby store's but I am pretty sure it is just acetone. In a bind I have even used my wife's nail polish remover which has acetone in it.
mustafa_m 06-18-2004 10:54 AM
RE: Thread lock
will try the above.... and anymoree ideas?????
mustafa
RandyT 06-18-2004 11:45 AM
RE: Thread lock
I have use CA Remover, the stuff I had was really thick so it stayed where it needed to be. Sorry can't remember the name, but it should work. Good luck.
DustOffUH1 06-18-2004 02:15 PM
RE: Thread lock
as suggested soak it in acetone,,,, its worked for me a number of times,,, nail polish remover works too, but a little slower
mustafa_m 06-20-2004 07:58 AM
RE: Thread lock
pl solved with acton... thanks guys
mustafa
