Window Tint
Hi all,
I'm wanting to tint the windows on by fuselage but I'm having problems sourcing Black window tint spray in the UK. I've found a "Smoke" tint spray but that is not the smooth finish I'm after. Any body got any suggestions? |
RE: Window Tint
If it's "smoothness" rather than "blackness" that's the problem, how about sraying on the inside of the window, and letting the clear plastic window provide the sheen? Also, you can always get a polish(I find perspex polish is a good starting point) that when applied to the outside will really make it gleam!
If It's "Blackness", multiple coats might work Cheers Chris |
RE: Window Tint
Or you could get hold of a carbon fiber screen, looks pretty cool!
Failing that you could use a dark or black clothing die, It will stain the plastic of the canopy screen. http://www.runryder.com/gallery/18162/61798876.jpg |
| All times are GMT -8. The time now is 12:41 PM. |
