RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Starter for YS80 help ! (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/218397-starter-ys80-help.html)
RCUser012 08-04-2002 09:27 PM
I can not seem to be able to start my YS80 on my X-cell SE.. I am using the high torque Sullivan starter, and it does not have enough pull, even on a brand new, fully charged 12v battery ...
what are you guys using for starting the 80s ?? should I be getting one of these $120 geared starters ?
please help !
Wojtek
Dazzler 08-04-2002 10:03 PM
No you dont need one of those expensive starters, look no more here is the ticket. You want a magnum starter with torque drive, it cost a whopping $30.00, it starts up my YS 80 with no problem, hasnt bogged it yet, even if my 12volt is not fully charged it just turns the crap out of it. Daz...
Here is the link:
http://www.hobbypeople.net/gallery/237960.asp
RCUser012 08-04-2002 10:10 PM
I just ordered it .(the magnum).. If this does not work, its off to home depot for a high speed cordless drill (with a torque limmiter of course )
thanx !
WOjtek
Dazzler 08-04-2002 10:13 PM
You can forget Home Depot, you wont be sorry with your purchase. After you get it and see how strong it is please post how much you like it so others can benefit from this starter on the bigger engines. Not alot of people are aware how strong magnum starters are. Cya, daz...
You ordered the one I had on the link, right?
The other day my freind used it on his YS120 pattern plane, and it turned that thing over like it was a .049
RCUser012 08-04-2002 10:32 PM
right from the link I bought it ... :) one of these spontaneous deals :)
wOJTEK
Dazzler 08-04-2002 10:43 PM
Cool, also just to let you know I started using this starter when my engine was brand new, which is the tightest the engine will ever be, and even when the engine was new, the magnum had no problem.I started up my OS 160fx with it the other day, and this engine would never start with my sullivan, sometimes start with my Kavan starter if 12 volt was fully charged, manum to the rescue, again started it without hesitation.
Whenever I'm at the feild now and someone has a problem spinning their engine, I cant wait to run and get mine and crank that puppy over for them, I almost fell one time running too fast to go get mine :D .
And I'm no Rep. JUST A HAPPY CUSTOMER!!!
RCUser012 08-05-2002 12:49 AM
I actually burned out my Sulivan !! nice for planes but not the YS80 on my X-cell ... what I also have that could use a good starter is a Henseleit Rocket, that has a OS 1.40 in it ...
I will post my results when I use the starter .. I figure i should have it in the mail on Tuesday ...
thanx for the advice !
Wojtek
rickc 08-05-2002 11:39 PM
You just need to step up the voltage. My Hobbico Torquemaster 90 will turn my .80 over with authority. The key is 14.4 volts.
Here is a pic.
http://home.insightbb.com/~rickc/Starter.jpg
Dazzler 08-06-2002 12:13 AM
You dont need to step up volts with the Magnum, you can actually be low on your 12 volt pack, and it'll spin it with plenty left over, and its more compact to boot than those big bulky starters. Daz...
RCUser012 08-06-2002 12:24 AM
i don't like battery packs on the starter ... i preffer the old fashioned power pannel 12v method ...I got my hopes on the Magnum !
Wojtek
duelist 08-06-2002 10:45 AM
If the Magnum doesn't work, you could get the Dynatron. On 24 volts it will spin my 2 c.i. plank motor like it is a 40.
RCUser012 08-06-2002 12:47 PM
the Dynatron, thats the Sulivan right ? I actually burned mine out trying to spin the 80.. got so hot I burned my hand !
Wojtek
runamuk 08-06-2002 02:00 PM
I'm using the Sullivan 24v starter with 2 - 6 cell electric car batteries hooked up in series and tie wrapped to the starter. This works very well but does require rather frequent charging. Others I've seen use 2 - 7 cell electric car packs with much better times between charges.
duelist 08-06-2002 03:00 PM
The Dynatron is not the yellow sullivan starter. Its about 1-1/2 times the size and is ALOT more powerful.
Dazzler 08-06-2002 03:11 PM
Isnt that Dynatron like $90.00?, and runs on 24 volts?, and huge at that.
Wiwanczyk, should have that Magnum soon, so you guys stay tuned for his personal experience, and then you can leave all that heavy stuff at home, and sport the Magnum.
RCUser012 08-06-2002 03:31 PM
I should have it via UPS today .. My ys80 is eagerly awaiting its arival !
Wojtek
duelist 08-06-2002 03:35 PM
Only $69, it is 1-1/2 the size of a regular starter and runs off 12/24v. The starter has a torque wind so @12v it will start a more stubborn engine than a regular starter, and on 24v it could start a Harley. :D I think it is actually rated to start up to a 2.1ci engine- no other starter in its class is rated that high.
Most of the time I can start my OS 91 on 12v but sometimes I use 24 if the engine is a little stubborn.
Pic
http://www2.gpmd.com/image/s/sulp1703.jpg
gjestico 08-06-2002 10:41 PM
I'm sure that magnum starter is the one that Jason Krause uses. I saw him with it at the Cascade heli fly recently. He didn't know what brand it was but the picture looks identical. So now you can say you and Jason are in the same league as far as starters go!!!!! :D
RCUser012 08-06-2002 11:57 PM
That dunatron is exactly the same thing as my sullivan !! It burned out on me, and got so hot it was burning my hand !
I got the Magnum today... I open the box .. and %#$%@ !!! its so small !! ... atatched my xcell cone adapter and hit the back yard .... woo hoo !!! this thing spun my ys80 up like a bat out of hell !!
All I have to say is that I just ordered another one ! I will use it for my plank engines (I have a YS100 4 stroke, and a os 1.40 that this thing turned over easily ! )
Dazler, great advice on the starter ! thanx ! the sullivan was the third started i had and still was not good enough .. the Magnum is cheaply priced too, i like this thing .. I guess time will tell its durability, but with this price, i dont care if i even have to buy a new on every 12 months .. (it does look very solid though ! )
brg,
Wojtek
Dazzler 08-07-2002 12:09 AM
What did I tell you!! I knew you would like it, your welcome. Plus its size is great for Heli's, fits right in the palm of your hand. Now when your at the field, wait till someone has a problem turning their engine over, and zap it with that Magnum, and see the power.
Now the rest of you guys that needs a good starter, thats 2 out of 2 happy customers, and like wiwanczyk said you cannot beat the price. Enjoy, Daz...
Furyflyer2 08-11-2002 06:56 PM
Looks like I will be ordering one today, I'm having trouble starting my YS 80. Thanks Daz for the info.
Dazzler 08-11-2002 08:46 PM
Furyflyer2, good choice, again you will be happy with the starter. I noticed one thing about athe YS engine is to make sure after every flight you cut off the fuel supply to the carb with a fuel cut off tab. Because with YS, it can get flooded real easy after every flight if you allow that pressure to keep pushing fuel in that carb. Daz...
RCUser012 08-11-2002 09:43 PM
here is another tip on starting up new angines that are tight ...
loosen the glow plug and start the engine with it 1 - 1.5 turns out .. the moment the engine starts, bring it to an idle, and tighten the plug ... after a tank or 2 on a new engine this becomes unnecessary .. some gassoline engines actually have valves on them that allow the engine to start on a lot lowwer compression, and when the run up, the valves are closed for more power ..
that Magnum starter is great ! I started a brand new OS .91 DF engine with it today !!
Wojtek
Cougar-RCU 08-12-2002 12:00 AM
Yep I used the 12/24 that duelist
uses (Sullivan ) Always Had plenty of tork
and power!
good luck! :)
Jeff
=XGC= OzZ 08-12-2002 12:05 AM
What are the guys useing for the 90 ?
Wow Bigger engine bigger pain in the ass....
