3/4 stick hover
anyone flying with 3/4 stick hover in normal mode? been trying to set up my machine for 3/4 stick hover for some time now and recently upgraded to a jr 6102 from a 662 for more throttle/pitch points hoping to make it more accurate but my throttle setup is becoming more and more a source of frustration. seems impossible to get the correct linkage/curve setup at 3/4 stick 50% throttle with everything square. i've used ray's authoritative helicopter manual extensivly for referance on everything and is a valuable source of info. however i feel the throttle section is lacking.
please help!! really need to get past this to advance. jr venture cp always jr!! |
RE: 3/4 stick hover
why would you need 3/4 stick hover in normal mode? when you start flyin around you wont use normal mode execpt for starting.
RE: 3/4 stick hover
This method is becoming the "new" normal mode Dan. Sorry sherm, I have an 8U and havent toyed with doing that yet but I hope to soon.
RE: 3/4 stick hover
Having a 3/4 stick hover in normal mode will allow you to switch between normal and idle-up anywhere above half stick without dropping altitude. If you have your normal mode curves set for a 1/2 stick hover, then at 1/2 stick you are around +5 degrees of pitch and about 50% throttle. Now, your idle-up curves are set for 3/4 stick hover which means 0 degrees of pitch at 1/2 stick and less than 50% throttle. Doesn't take long to see that if you're in a normal mode hover and switch to idle-up you'll instantly go from +5 degrees and 50% throttle to 0 degrees and less than 50% throttle. Without instantly raising the left stick, your heli's gonna drop.
Now for setting the throttle curve: Make your adjustments to the linkages in normal mode. Set the left stick at center (half stick) and make sure your curves (throttle and pitch) are at 50% in the transmitter. The throttle linkage at that point should be at 90 deg. to the servo arm and the arm on your carb. The carb should be 50% open. Your collective pitch should be set to 0 deg. at this point by adjusting the linkages to the head. Now you can set the pitch curve to +/- whatever for normal mode by moving the stick to the top and bottom and adjusting the corrosponding values in the transmitter. For a 5 point curve, you're pitch curve should be fairly linear and go from 0deg. at center stick, +5 deg. at 3/4 stick, and +9 or 10 deg. at high stick. The bottom half is similar, but you may not want -10 deg. at low stick in normal mode. You might go -2 deg. at 1/4 stick, and -4 deg. at low stick. Now you set the throttle curve for normal mode remembering that you've already set the linkage properly, so all adjustments will be made in the transmitter. Your hover point is 3/4 stick, so the throttle curve point at 3/4 stick should be about %50 in the transmitter. High stick should be approaching %100, but you will need some flight testing to better determine the throttle opening required at full collective. Now, at half stick you have 0deg of pitch and very little load on the engine, so your throttle curve point for half stick might be about 30%. Low stick in normal mode is where you want a good idle, so set it idealy at 0 in the transmitter, but may have to be about %5. The point for 1/4 stick should be about half way between low and 1/2 positions. In this case, %15 to %17 at 1/4 stick. Setting the idle up is easy now (providing you want to start out with the same headspeed in both modes). There are no linkage adjustments to be made, just points on the curves. The pitch curve in idle-up is the same as normal from 1/2 stick to full stick. 0deg. at center stick, +5 deg. at 3/4 stick, and +10 at high stick. Below half stick, you want -5deg at 1/4 stick and -10 deg. at low stick. Done here. The throttle curve in idle-up is the same as normal from 1/2 stick to full stick. %30 at center stick, %50 at 3/4 stick, and %100 at high stick. Below half stick, you want %50 at 1/4 stick, and %100 at low stick. Done here. Now your curves look like this: Normal mode low stick = idle and -4deg. 1/4 stick = %15 and -2 deg. 1/2 stick = %30 and 0 deg. 3/4 stick = %50 and +5 deg. full stick = %100 and +10 deg Idle up mode low stick = %100 and -10 deg. 1/4 stick = %50 and -5 deg. 1/2 stick = %30 and 0 deg. 3/4 stick = %50 and +5 deg. full stick = %100 and +10 deg. Now you can spool up, lift off, and hover in normal mode then switch to idle-up in a hover and fly off into FF, aerobatics, whatever. Ben |
RE: 3/4 stick hover
ok sweet!! exactly what i was lookin for...gonna get to work and do some flight checks. think i see what i was doin wrong....tbc thx ben
RE: 3/4 stick hover
BEEEUUTIIFULLL!! i was trying to set up the trottle at 50% with the stick actually in 3/4 rather than setting it up at 50/50 then adjusting the curve..works great....headed out for my first loop!
RE: 3/4 stick hover
Glad you got it worked out. Now, just make sure you're in idle-up before you try any loops!
Ben |
| All times are GMT -8. The time now is 08:32 PM. |
