What is the diffrence between these pcm and ppm
I am using a FP-R127DF Futaba dual conversion FM 7 channel receiver. With 4 s3151 servos, and a Futaba 401 gyro with one s9254 servo.
What is the diffrence between ppm and pcm, I think i know the diffrence between these and pccm. these do not use the electronic mixing functions on the head. correct. Please help to explain which is which and why. Along with what the Shuttle plus is. |
RE: What is the diffrence between these pcm and ppm
Christian,
I think you are getting a couple different subjects confused. I believe what you are referring to as "PCCM" is the CCPM (cyclic/collective pitch mixing) used on helicopters. The electronic type of CCPM uses 3 (or 4) servos to control the swashplate movement by the way of mixing functions within the transmitter. Your Shuttle Plus does not use the electronic CCPM mix. PPM (Pulse Position Modulation) and PCM (Pulse Code Modulation) are a totally different subject referring to the type of modulation used to transmit the signal from transmitter to receiver and is not specific to a type of plane or heli. [link=http://www.dubai*********.org/ppm_or_pcm_or_ipd.htm]PPM or PCM or IPD(New)[/link] is a good description of the differences between these 2 systems. Your Futaba 7C transmitter can be switched to transmit using either PPM or PCM. This is saved in each different model memory, so you can have different types of receivers in each model. The receivers only operate on one type of modulation or the other. Hope this helped. Keith |
long story short, PCM is more reliable.
ppm is basically fm
3d type,
Both PPM and PCM operate on the FM band. The difference is in the type of modulation. Keith |
Both PPM and PCM operate on the FM band. The difference is in the type of modulation. - Tim |
good explanation, tim. thx.
You are absolutely correct, Tim. I guess I shouldn't have been trying to reply after 4 hours sleep in the last 3 days.[:o]
Thanks for the correction. Keith |
Tim must have had more than 4 hours sleep!!!hehe
Great reply thanks for sharing |
| All times are GMT -8. The time now is 04:10 AM. |
