Servos for raptor 50V2
Hello.
I was thinking if 4 Hitec 635HB and a futaba 9254 servo for the rudder would be enough for this heli? Or I will need something stronger for pitch or digitals? What do you recomend? Also, do you know if I can use the futaba GY401 with my Futaba 8U non super? Thanks a lot in advance. |
RE: Servos for raptor 50V2
Ive been flying one with 635's on cyclics and collective for a few months, they do the job just fine. also been using a simple standard servo for tail (works fine with the GY401).
on a second heli ive been using 635 on cyclics, a nice hitech digital on collective, and the 9253 on tail, i like the digital on collective, lets you bounce it around a bit harder. |
Well you still alive. Got back from Kirkland and have been busy finally slowed down. Got the helo out started it and will start to practice hovering soon, been on the simulator. look foreward to hearing from you.
Thanks a lot for your help.
But can I use the combo GY401+S9254 servo with the futaba 8U non super? How can I switch from hh mode to normal mode if I don“t have the gyro program menu in my radio? Thanks a lot: Daniel |
Yeah you can use that. set the sensitivity to a channel that is not being used. then use that channel and set the apvs to get the sensitivity as per the 410 manual.
| All times are GMT -8. The time now is 11:46 PM. |
