Upgrading TX Battery
I have a Raptor 30 V2 with a Futaba T6XAS. The TX and RX batteries are worn out I would like to upgrade these. I have read that getting a RX battery with higher Mah is good but I am not sure about doing the same for the TX. Any imput would be greatly appreciated.
Kevin |
RE: Upgrading TX Battery
I'm not real experienced with RC. Butt I can tell you this. If you have digital servos, they will suck some juice. I've also read several posts and talked to guys at the fly field. For my raptor 3 V1 they recommended in the neighbourhood of 2100 mah. The 600 mah that was installed they quickly frowned on. I already had 1800 mah for my radio so I didn't go any higher. After 1 flight my radio takes about 15 minutes to recharge using a quick field charger. The heli battery takes about 30 because of the digital servos I recently installed.
Hope this helps Dennis Sachse, Tx |
Thanks for the reply! Anyone else?
As long as you keep the voltage and cell count on the tx you can upgrade it.
Get the biggest rx battery you can afford, I have a 4000Mah in my Raptor 50, I can fly all weekend without recharging. |
I get my TX batts from here:
http://www.batteryspace.com And my RX batts from here: http://www.cheapbatterypacks.com Batteryspace will sell you two 2000mAh NiMH TX packs for about $26 (plus shipping... ~$6 I believe), and CheapBatteryPacks will custom make you a good RX pack... I use four 2500mAh NiMH A cells in my helis... |
-pkh-,
I looked at batteryspace and saw that they hd the 2000mAh NiMH TX packs on sale for only $12.99 on sale,,,,, WOW!! It looks like I will order these. I also saw these for the RX, http://www.batteryspace.com/index.as...ROD&ProdID=184 What is your opinion on these? You said that you get yours at cheap batteries Why not at battery space? |
ORIGINAL: kdolz -pkh-, I looked at batteryspace and saw that they hd the 2000mAh NiMH TX packs on sale for only $12.99 on sale,,,,, WOW!! It looks like I will order these. I also saw these for the RX, http://www.batteryspace.com/index.as...ROD&ProdID=184 What is your opinion on these? You said that you get yours at cheap batteries Why not at battery space? If batteryspace had a four A cell RX pack, I would have bought it from them, though... |
I was trying to figure out the correct configuration, wire, connectors, ect.... could you show me the setup that you at using?
I would like to order from cheapbatteries, But am confused about all there choices! Thanks, Kevin |
Here's the brick pack setup I use in my Raptor 50V2 (I use a flatpack version of this for my JR Venture 30CP):
Step 1: 4 cells Step 2: CBP2500A cells Step 3: Brick (or flat, whichever is best for your application) Step 4: 22AWG Wire (only wire you can get with Hitec Male plug) Step 5: Hitec Male Plug Step 6: No (copper bar upgrade option, not needed here) That's it... |
Check out Hangtimes Hobbies, [link]http://www.hangtimes.com/[/link], they are fantastic. My recent order for a replacement Rx pack for my R50 V2 came the day after i ordered it and I paid for no special shipping. You can also call them and you will get good advice, along with the clear and concise info on the webste. I put a 1650mah NiMH battery in my JR8103 Tx and I have gotten 13 flights between recharges and still had battery available, where as the stock pack was only good for 3-4 flights.
My stock 1100mah NiCD Rx battery was only for 1-2 flights so I got a 1950mah NiMH for my R50. |
What is your opinion on these? Mike |
| All times are GMT -8. The time now is 03:49 PM. |
