Heli Database
I was noticing like I do, a lot of you are using the same set-up in a lot of your helis. I made my own personal heli data-base on set up with certain tuned pipes and different equipment. I have it all the way back to 1996 saved on disc for back-up. I can always go back and read my issues-fixes and maitenance logs alike.
I noticed my clutch liner was wearing thin on my RG, so I went back and checked to see what month I built it and the specs when I last checked it. Works well on some things-Just an idea....anyone else doing this? |
Heli Database
I Use the JR DataSafe -- The problem is you can Not see the changes untill you download the old setup back into your radio! They need to have a program were you can see and do changes on the computer. I think your idea may be the way to go! Good Idea!
Dr.Tim |
Heli Database
I do that in MS Excel. I only do it on settings like throttle on pitch curves and ATV and trim.
| All times are GMT -8. The time now is 05:38 AM. |
