?Glitch with Hitec 6 ch FM Dual Conv Reciever: why
I am running the Hitec 6 ch dual conversion reciever on a 50 size heli. The electronics include 5-cell battery with voltage regulator.
* The problem: I am experiencing intermittent glitches in hover just above 3/4 stick. * I have tightened muffler, checked crystal and antenae, and all moving parts for breakage. Any ideas would be appreciated, thanks. |
RE: ?Glitch with Hitec 6 ch FM Dual Conv Reciever: why
Metal to metal rubbing somewhere.
A bad bearing somewhere Poor antenna routing All three come to mind |
Thanks for the info.
I found the problem. I am running the Futaba GY401 Gyro which has a Sensitivity Switching Connector. I remembered that the problem didn't exist prior to hooking the SSC up, so I unplugged it from the TX and no more glitch. I will check to make sure I had it plugged into the right channel and make sure it is adjusted properly. Anyone else having a problem with these units please give me a heads up,,,much appreciated. |
What do you mean SSC hooked up? I have GY401 on my .30 size heli and am not sure what your referring to when you SSC.
RevGQ:: ... the Futaba GY401 Gyro which has a Sensitivity Switching Connector ... HeliTB:: ... not sure what your referring to when you (say) SSC. |
Thanks for correcting my english.
Check out the SSC connections (channel 5 and signal wire) and test flew the heli again. Again I began experiencing glitch. I remove the SSC and glitching ceased. At this point, I may have a damaged gyro. Gyro is setup as per instructions found on the Raptortechnique website. Please post any ideas.
A quick PS: the copter is the Audacity Tiger 50. I am also having the problem of blades getting out of track during flight. I think that my paddles are moving. I will attempt to tighten them. Any help would be appreciated.
RevGQ...I looked in my manual and to my suprise it's the yellow wire that goes to channel 5. I just never heard it referred to by its proper name.
