4 stroke Power
Hi All
Has anyone though about putting a 4Stroke in a chopper for power ? Cheers |
RE: 4 stroke Power
ORIGINAL: The Ghost Hi All Has anyone though about putting a 4Stroke in a chopper for power ? Cheers The problem is the gearing would have to be designed with a 4 stroke in mind because they produce their power in a much lower rpm range than the two strokes. Also they only produce power every two cycles of the piston so the engine is alot heavier relative to the power it puts out. Over come those basic design issues and it would sound cool but performance would be underwhelming. |
RE: 4 stroke Power
Century had one too... They overheat and don't have the power.. that was then and they should try again.... I wouldn't buy one... with electrics coming on strong why would anyone?
RE: 4 stroke Power
I know about the gearing but the newer 4 strokes have a lot more power than the older 4 strokes, and the 2 stroke noise is a little on the ears to fly in my backyard all the time (upsets the fokes) Just thinking of using a Satio as the noise is not the high pitch as a 2 stroker.
Cheers |
RE: 4 stroke Power
you can also get a vario 4stroke . ive got a sky fox with a 91 os 4 stroke.but i took the engine out after a short time..
i have to say i was/am very disapionted with it..it had trouble just to hover without overheating and i had to foreget about fast forward flight. i changed the lenth of the blades too going from long to the shortes i could use on it but it was always underpowered .. another flyer on this forum though said that i might have better results if i had changed the type of exhaust i was supplied with it.. admittidly i didnt use it with 30% nitro,, think i used 10 %. |
RE: 4 stroke Power
The noise issue is a red herring.
I had a Nexus Legato, it is exactly 0% quieter than my current Raptor with a TT46 in it. |
RE: 4 stroke Power
Correct me if I'm wrong, but I believe this is a 4-Stroke: http://www.bergenrc.com/Twin.php
And I can say (as indicated above) after several flights with one that they are every bit as obnoxious. My vote for a REX 600! :) - Chaz |
