RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Bench Run or Not ? (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/611674-bench-run-not.html)
bluefronted 03-09-2003 04:24 PM
Bench Run or Not ?
Hi , will bench running / breaking an engine on a bench be better then breaking it on a heli.
I ran my engine a bit lean on a full castor blend , will this cause any major problems on this new OS32SX-H.
thanks
Lynx 03-10-2003 03:22 AM
Bench Run or Not ?
With a 32SX-H you're better off babying it a bit at first because it's non-ringed. Use more oil, and don't lean it out if you can help it. Breaking it in on a bench is probably a great idea, considering how rough serious flight in a helli is. Just make sure you supply a load or you're not really breaking it in. I don't know what the proper pitch to use is but a moderate sized propeller makes for a good load.
bluefronted 03-11-2003 11:29 AM
Bench Run or Not ?
Hi , I just found out that you get 3 types of OS32SX-H engines ,
-an ABC type
-a Ringed type
& a Ringed pull start.
Fortunatley I have the pull start type.
