Help! Almost crashed. Weird problem
Thanks Adam
More good info. I've got some of those bags and may try it if I need to. |
I've had glitch problems that went away when I changed my antenna routing, much like the zip tie thng mentioned above. Sometimes a bit of antenna would be caught under rubber bands on the radio tray. When I freed it from the bands I had no more glitches. Hey, this is turning out to be a good thread!
I have my antenna routed through fuel line, and then zip tied onto the base loaded antenna. It doesn't touch the frame. The base load is double sided taped on.
I still had the problems. I had all servo wires out the front and to the side, and I had the antenna wire coming out the back and to the other side so as to not cause interference. Still had the problem. Used the 3M anti-static bag, problem gone. Like I said, I know I didn't fix the problem, but at least I can fly (well trying too anyways) |
well i put the new bearing on the clutch bell and i took the switch out form the frame and started up with out the blades in my back yard i pass half trot. and i dont see the glitch no more i will fly it this weekend and i will see if is real gone
(hope that the glitch problem was the bearing LOL) |
well i got the same problem i will change now the digital servos and putting std. servos just to try it and also notice that the swash plate on high pitch and left or right movement was hitting the anti-rotation pin i fix it and will see tomorrow if stop that dam glitch thanks
| All times are GMT -8. The time now is 11:45 PM. |
