RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Winter Flying? (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/6951352-winter-flying.html)
kurt10 01-22-2008 04:43 PM
Winter Flying?
Whenever I fly my T-rex outside the servos act a little weird. It's only about -5 out right now. Does anyone know if there are any servos out there that can handle the cold better, or should I just stick with flying indoors and not fly outside in the cold at all.
I had a blade CP Pro that flew fine in the winter.
Thanks in advance,
Kurt10.
Druss 01-22-2008 05:14 PM
RE: Winter Flying?
what servos are you using on the trex? I fly outdoors as well and i always let the heli sit outside for a few minutes (battery inside) until I'm ready to fly. it's the temperature change that screws things up.
kurt10 01-22-2008 09:12 PM
RE: Winter Flying?
I use the eflite (same as DX6) s75 servos.
nitrohog 01-22-2008 09:46 PM
RE: Winter Flying?
I've flown down to about 10F and 10 knot winds with HS65MG servos on the cyclic and futaba 9650 on the tail with no problems. Aren't those servos a little underpowered?
nitrohog 01-22-2008 09:49 PM
RE: Winter Flying?
I should also mention that the ball links tighten up in the cold making the swash seem sluggish and slower than normal.
The Codfather 01-22-2008 09:56 PM
RE: Winter Flying?
Try a little silicone spay on the parts to keep the ice from forming on the balls and links. Remember -5 plus the windchill from the spinning around at 70mph or more could easily freeze up the head.
kurt10 01-22-2008 10:28 PM
RE: Winter Flying?
How do you mount the HS65MG servos on the t-rex (or maybe jsut the se v2), because there is only one hole (in the centre) and the HS65MG servo has 2 holes on each side. Do you just drill another 2 holes?
Kurt10
haasjj 01-22-2008 11:19 PM
RE: Winter Flying?
I don't know if they changed or if mine came with 3 holes or if I drilled them out, but mine have the 3rd hole in the center which is where it is mounted.
nitrohog 01-23-2008 04:38 PM
RE: Winter Flying?
Mine have three holes in the tabs too.
BarracudaHockey 01-23-2008 05:27 PM
RE: Winter Flying?
I just drilled mine in the center. I set up a heli for someone with those s75's and there is no way I'd use them in or reccomend them for a 450
I hate winter flying around here, I have to wear a long sleeve shirt :D
Druss 01-23-2008 06:31 PM
RE: Winter Flying?
ORIGINAL: BarracudaHockey
any comment on the ds75's used in the blade 400? I've also used the s75's before and think they are junk, barely adequate for a 300 size. I can't see the digital version being better to the point that it can be used on a 400/450.
devens 01-23-2008 08:26 PM
RE: Winter Flying?
The new DS75 servos are much better than the older version. The have excelent servo arms, ball bearings and finer splines on the output gear to eliminate slop in the servo arm. Are they enough for a 400 sized heli????
I am not the one to judge that but if there were very serious problems they would have come out during the proto type trials I would hope.
BCH are you doing a review on the e-flite Blade 400 or is anyone doing one for RCU? I wouldn't trade my Mini Titan for one but with a spektrum 6ch radio for $450 ish I think the Blade 400 is a heck of a deal for a beginner! <--- off topic sry
D
BarracudaHockey 01-24-2008 10:44 AM
RE: Winter Flying?
If they send me one.
The next electric heli review will be this one ....
http://www.beamheliusa.com/
