RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Need help....... (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/75170-need-help.html)
J13ntv 03-11-2002 10:53 PM
Need help.......
Since i am going to buy a power panel, can i use it to check my volts in my receiver battery? I know they sell things with panel ready clips with the end of your receiver battery for charging and you use that with a volt meter, could i plug it into the power panel and it will shows the volts or something? LMK thanks
Blair 03-12-2002 12:21 AM
Need help.......
As a rule no. You might find one that will will do it, but I can't think of any at the moment. Most powerpanels will just give you 12 volts for your starter, 1 1/2 volts for your glowplug, and 12 volts and a 2-way switch for you electric fuel pump. Some will even recharge your ni-starter but I don't think I've ever seen one with an ESV or flight pack charger all in one.
Blair
J13ntv 03-12-2002 12:24 AM
Need help.......
So then, i should really buy a volt meter, is it worth it? Liek 20 bucks when i am done buying the meter and wires... I know its not much but adds 20 muchs on top of the 140 bill already :) Know what i mean
Blair 03-12-2002 01:59 AM
Need help.......
No, buy an Expanded Scale Voltmeter. A regular voltmeter is practically useless. You need to be able to apply a load to the pack to see how it responds. Loads usually vary from 2-400ma's.
It will tell you whether your pack is safe to fly or not.
Blair
