RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   HB 3D Pro pitch problem (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/7620832-hb-3d-pro-pitch-problem.html)
yukka62 06-15-2008 09:13 AM
Greetings all,
Can anyone give me some advice on setting up the pitch curves on my Century 3D Pro,when i throttle up i get major neg pitch & the heli tries to force itself into the ground!!,i can get pos pitch by using the stick to adjust it but this does'nt seem right.I have copied the set up off my mates Blade 400,but the problem persists.I am using a DX6i,AR6200 Receiver with 05hs zeta smart servo's & an NT400 head lock gyro.
Any help or advice will be gratefully accepted
Thaks guys :D
Druss 06-15-2008 12:39 PM
RE: HB 3D Pro pitch problem
You should list your pitch curves along with the actual pitch at bottom, mid and top throttle. Then we can help. You should also list the pitch in idle up mode too.
tippy 06-17-2008 05:25 AM
yukka62:: ... Century 3D Pro ... when i throttle up i get major neg pitch & the heli tries to force itself into the ground!!,
Pushing forward on the collective stick ( "throttling up") should give you more positive pitch. If it's going less positive then your pitch function is reversed. If your heli is non-CCPM then change the setting of the pitch channel (nom/rev). If your heli is CCPM, then change the polarity (+/-) of the pitch setting in the SWASH menu.
yukka62 06-17-2008 03:18 PM
Many thanks to all who offered help with my pitch problem,i applied the settings brac1960 sent me & the old girl lifts off, hurray:D
Only problem now is a crash is closer,haha.
Cheers guys,keep flying.[8D]
brac1960 06-17-2008 03:44 PM
ORIGINAL: yukka62
Glad to hear that my setting helped!! Happy flying:D
