Blade Balancing. How close?
I have some woodies and they are half a gram different. Is it practical to try and get them closer? Will I notice any difference?
Thanks, Pete |
I usually try to get mine down to .01 gram or less. The closer the better.
It's pretty easy with some sanding, drilling or adding a drop or two of CA on the blade root or tip as appropriate. Don't forget blade C/G that will affect things also. |
| All times are GMT -8. The time now is 05:28 PM. |
