Mini Titan
Hi
I'm having a problem with my Mini Titan cutting out in mid flight. I'll be out flying curcuits and the heli will just drop out of the air. Has any one had problems with ACERC ESC controllers on these models? i've checked battery and rc gear and they are ok, so i can only think it's the speed controller. Yak54 |
RE: Mini Titan
Probably the battery, have you tried more than one?
RE: Mini Titan
mine is aso cutting out dont know why. got a new battery but still does it after about 3 minutes in the air. thinking maybe the speed controller is overheating.
RE: Mini Titan
Check the maximum discharge rate of your battery and see that it meets specs.
RE: Mini Titan
Sounds like the battery protection function of the ESC is kicking in. There's light, standard, and heavy discharge protection. I haven't check mine in a while but I seem to recall experiencing the same this problem and I think I changed mine to heavy discharge. I'd have to check to be sure.
Just make sure you time your flights so that you are only using 80% of you packs capacity. I'll get easily 6 minutes on a 2200mAh pack and put in a little over 1700mAh. |
| All times are GMT -8. The time now is 03:48 PM. |
