GY401 use
Can a GY401 gyro and S9253 servo be used with a JR radio and receiver? Also can this gyro be used with a 6 channel radio?
GY401 use
Yes the JR/Futaba gyro thing works well... In fact, I run a PCM10X with all Futaba (9252) servos, and the 401/9253 combo that you mentioned... I've been using this arrangement for about 3 years now and it works great... I don't have a JR servo or gyro in the house... But I do like their TX and RX's...
As far as using it with a 6channel radio, I don't see why not, but maybe there is a reason I am unfamiliar with... Someone else will surely elaborate... bigTim |
GY401 use
yes that should work just fine with a 6 channel radio,i think 6 channels is the minum of channels you can go,now if you want to hook any thing else up to the radio like a co-pilot re-tracxts ect then you need more channels .
