RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Programmin Futaba 7C, THROTTLE CUT FUNCTION? (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/9755685-programmin-futaba-7c-throttle-cut-function.html)
apipertoo 05-24-2010 10:10 AM
Has anyone here ever programmed the throttle cut feature on the Futaba 7C Radio? BOTH myself and a friend of mine have this radio and neither of us can figure it out ?? HELP !! ??
Thanks in advance for any help.....
BarracudaHockey 05-24-2010 02:27 PM
RE: Programmin Futaba 7C, THROTTLE CUT FUNCTION?
Just enable it and set the percentage to where the servo moves to full closed when you activate it.
It doesn't work in throttle hold, if memory serves you have to be in normal mode.
rcjon 06-03-2010 07:30 PM
It works in throttle hold. I use it all the time.
bikemad 06-07-2010 01:56 PM
it's well worth the work to get the throttle cut or hold to work but check the trim after, if your 7C is the same as my 10C you set the trim and pitch curve for hold/cut separately, i.e. you can have many different trims,
It's so useful, on very windy days when I bring my heli in to land I get about a foot of the ground and hit the switch, the heli lands in a controlled and surer way with no chance of the wind getting under and lifting it up again, plus it makes the heli a bit safer when your putting in the battery etc.,
