RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Help Setting up Rx on trex 450 pro (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/9907671-help-setting-up-rx-trex-450-pro.html)
nick4622 08-03-2010 07:52 AM
Trying to set up all the plugs right. The manual is not really clear as to were the plugs go.
I have a Ar6200 wit a Dx6i, can anyone tell me what order Ihave to plugall the wires in.
The servos ESC and gyro that is.
Gyro has two wires, one plug of has only one yellow wire.
This is a trex 450 pro just built and ready to wire up so any tips would be apreciated.
jrelkins1 08-03-2010 08:07 AM
RE: Help Setting up Rx on trex 450 pro
If you look on page 17 of the Align manual (for the 450 sport) it gives the recommended servo inputs to the receiver for JR.  Also go to www.Helifreak.com and download Finless Bob's video's.  They will help a lot with setup although he uses a Futaba.
nick4622 08-03-2010 08:14 AM
My problem is that Im using a spectrum AR6200 with the dx6i and the names are kinda different like theres no pitch channel on this Rx.
but if someone has a setup similar to this can you tell me what order or which plugs go were, Like Isaid the manual does havesome info but not with withtype of reciver. Thanks all.
nick4622 08-03-2010 08:22 AM
Thanks anyways but i think I found what Ineeded
Try this for size,
AUX1 - Rear/front Right Servo
GEAR - GYRO remote switch Connection
RUDD - Gyro
ELEV - Front/rear Servo
AILE - Rear/front Left Servo
THRO - Throttle
BATT - Bind Clip when binding
