RC Helicopter Heaven Support Click here for help with all your RC Helicopter Heaven questions.
Belt cp battery
Old 05-03-2008, 05:21 AM
jimmy 1987
Default Belt cp battery
The stock belt cp battery takes up to 5 hrs to charge with the stock wall unit and balance charger, is this normal? is there any proper precautions to take with charging the battery as the manual says dont charge it for any more than 2 hrs
Old 05-03-2008, 09:43 AM
droggy
Default RE: Belt cp battery
5hrs?? Till light goes solid?? do you have a lipo tester to check voltage in each cell? Do not overcharge, each cell should not exceed 4.15 volts (what I was told)
Old 05-03-2008, 09:46 AM
droggy
Forgot to say, my stock chargr, the light flashes forever, I put a timer on and it usually takes each 1800mah, around 2 and half hours for full charge(green light still flashing)
Old 05-03-2008, 11:44 PM
jimmy 1987
can i use a different wall unit at all to charge it faster? i will look into getting a voltage tester, can i get one from a local hoby store or off the net?
Old 05-10-2008, 07:06 PM
brac1960
ORIGINAL: jimmy 1987
Yep . That is normal, It always takes mine 4-5 hrs to charge. I have three batteries and have charged all of them at least 20 times, without a problem.
Old 10-24-2008, 02:29 PM
helicrazedout
helicrazedout's Avatar
i bought the new esky charger and it onlt takes 1hr 30 mins to charge
