Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 01-20-2011, 04:39 AM
  #251
ricardinho
Default RE: C-ARF Ultra Flash build Thread + Video
hello any ideas on pilot sizes for this plane. i was thinking something funny not scale... thanks pat
Old 01-20-2011, 06:58 AM
  #252
Dave Wilshere
Slimline Xtreme pilots are about the right size.
Old 01-20-2011, 10:00 AM
  #253
raptorlogo
raptorlogo's Avatar
ORIGINAL: ricardinho
Hi Pat,
Mickey Mouse is the fastest funny pilot for the Flash !
Alain
Old 01-20-2011, 10:10 AM
  #254
ricardinho
very cute...i like that
Old 01-21-2011, 06:20 AM
  #255
mtnflyer14
mtnflyer14's Avatar
The axle bolts that came with my C-36/2 Behotec retracts are about 1/4" too long in the smooth axle part, such that the 1/4" threads (not 6mm unfortunately) bottom out in the strut before the head on the axle bolt comes up against the wheel rim. End result is that the wheel rim is 1/4" away from seating up against the brake assembly - ususable. Ray Lobonte (Comp-ARF rep) is trying to get the correct axles, but I will soon run out of time to be ready for the Speedworld/Desert Storm fly-in in Phoenix 11-13 February.
So, the question is, does anybody know if an airframe bolt with the correct 13/16" grip length (smooth, unthreaded part of the bolt) would be okay to substitute for an axle? I'm just not sure about the hardness/strength of the airframe bolts and can't find any info online about that. Just wondering if anyone else had used them. Thanks!
I will post some pics this evening of the pneumatic/electronics layout I used in the fuselage. I think it will be fairly efficient and accessible.
Regards,
Mark
Old 01-23-2011, 07:03 AM
  #256
mtnflyer14
mtnflyer14's Avatar
A few pictures on where I put the components in the fuselage. Generally, the ECU, solenoids and pneumatic stuff is on the left side, retract and brake valves and servos on right, Smart-Fly Power Expander in center in front of the UAT. The last picture shows where I had to relieve a little of the bulkhead and remove the nosewheel steering retract mechanism to get the air tank into the nose.
Regards,
Mark
ID:	1551626   Click image for larger version
ID:	1551627   Click image for larger version
ID:	1551628   Click image for larger version
Old 01-23-2011, 07:31 AM
  #257
ricardinho
looks very nice..
Old 01-23-2011, 08:25 AM
  #258
Dave Wilshere
ORIGINAL: mtnflyer14
Regards,
Mark
Mark, looking good and nearly there!
I think the threads are M6 and can be cut using a die to sort the issue.
Dw
Old 01-23-2011, 08:51 AM
  #259
dubd
dubd's Avatar
Mark, which rep did you order the plane from?
Old 01-23-2011, 03:55 PM
  #260
igorcar
Hello I got mine with David Shulman!
Old 01-23-2011, 04:07 PM
  #261
ricardinho
igorcar tuda bom!!!.. have you started assembly.. ricardinho
Old 01-23-2011, 05:17 PM
  #262
overnout
Anyone know if C-ARF plans to come-out with additional paint schemes? I like boring colour schemes and although I like the Blue Angel scheme I figure it would be hard to see in a blue sky. I liked they Thunderbird scheme on the old flash.
Cheers
Old 01-23-2011, 05:30 PM
  #263
ricardinho
i am sure they could do a thunderbird scheme because they already have it. you will have to check with a rep to see if there going to offer custom schemes...
Old 01-25-2011, 07:55 PM
  #264
gooseF22
gooseF22's Avatar
I just emailed Ray if I could get the wings/tail upgrade for my Tbird... will let you know.. I hope so!!!!..
Wouldn't this look sweet with a swept wing?
ID:	1553174   Click image for larger version
Old 01-25-2011, 08:12 PM
  #265
gooseF22
gooseF22's Avatar
I know you wanted funny but 1/7th is the scale of the flash. Its kinda inbetween most sizes I found. I cut down a 1/6 scale pilot. the cockpit is a 1/8 scale F-18 cockpit as you can see its gotta a big head.. (like me)
The 1/6 scale pilot is 12 inches, so Im guessing a 10 inch tall doll or so
ID:	1553210   Click image for larger version
Old 01-25-2011, 10:23 PM
  #266
Ragz
Ragz's Avatar
We test flew my Ultra flash last weekend.  Its has a classic P120 from 5 years ago.  IMHO, this is the smoothest nicest flying aircraft I have ever owned... and I have owned a lot.
Cheers
Anurag
Old 01-25-2011, 11:42 PM
  #267
Dave Wilshere
Anurag
That's great! it is smooth for sure. We have a few being finished at this time ready for the season ahead.
Colour schemes-most are available to order, the red Cheque scheme is available for sure, I've ordered a colour swop (same scheme different colours) talk with your reps and they can sort most things. But yes the T Bird scheme will suit it!
Dw
Old 01-26-2011, 04:22 AM
  #268
ricardinho
goose that cockpit looks awesome.. i love the thunderbird scheme.....
Old 01-27-2011, 02:17 PM
  #269
canenr
Look what showed up at my front door!
ID:	1554174   Click image for larger version
Old 01-27-2011, 02:55 PM
  #270
ricardinho
oh boy!!!!! mine should be here next week ... how she look?
Old 01-27-2011, 03:17 PM
  #271
Dave Wilshere
ORIGINAL: canenr
Cool, just needs some Motors & Rotors stickers
What equipment did you decide on?
Dw
Old 01-27-2011, 03:28 PM
  #272
canenr
Just like my CARF Eurosport, beautiful kit. Comes with everything and excellent fit. Thank you Andy Kane.
Old 01-27-2011, 03:32 PM
  #273
canenr
So far the plan is: Jet Central Cheetah turbine 31lbs
JR8411 servos all around
Dreamworks ProLink struts and wheels
Futaba 12Z radio
Old 01-27-2011, 03:57 PM
  #274
Dave Wilshere
It will rock with a 31lb thrust turbine.
Dave
Old 01-27-2011, 03:59 PM
  #275
skynet33
I finally got my UF last week after a 3 1/2 month wait, but all I can say is it was well worth the wait!!!!!!!!!!!!!
ID:	1554247   Click image for larger version
