Reload this Page >
The new Tornado sport jet
Old 08-15-2012, 01:19 PM
  #2476
TimWatson
Banned
Default RE: The new Tornado sport jet
ORIGINAL: TURBOMC
Come on TimWatson! You called the guy out by questioning the validity of his professional history and he flat out backed up his claims.Admityou were wrong to doubt him and move on. It's called being a man!
I asked a question and Henry replied. If you and others thing he always speaks the truth on here then that is up to you. Others have different opinions
Your definition of being a man is also interesting
Old 08-16-2012, 05:18 PM
  #2477
PHall
PHall's Avatar
If we can return to being adults......................I would like to know if anybody has pictures of what they are doing with the servosin the tail sections.
Thanks.
Old 08-16-2012, 06:12 PM
  #2478
Dblex
My Feedback: (81)
Dblex's Avatar
Mine were too tall on the elevators, so I had to make some custom spacers. But I used aluminum heli mounts that were 1/4in thick.
Old 08-16-2012, 11:57 PM
  #2479
BaldEagel
BaldEagel's Avatar
ORIGINAL: PHall
Thanks.
Version 3 or earlier as they have different mountings if I understand the V3 correctly?
Mike
Old 08-17-2012, 02:17 AM
  #2480
Xairflyer
Xairflyer's Avatar
There are different ideas for elevator servo's in the falcon thread
Old 08-17-2012, 04:01 AM
  #2481
PHall
PHall's Avatar
ORIGINAL: BaldEagel
ORIGINAL: PHall
Thanks.
Mike
Sorry, V3. I know the idea of what needs to happen but the tail is not overly accomodating.
Old 08-17-2012, 04:27 AM
  #2482
BaldEagel
BaldEagel's Avatar
Two ways you can go: build a servo box in the tail or fin and attach to both skins then attach servo to a purpose built/manufactured mount Hysoled to a plate glued to the skins, or build a servo mount on the servo cover and attach the whole thing by the cover screws, not my preferred option.
Mike
Old 08-17-2012, 04:44 AM
  #2483
Stobe777
Stobe777's Avatar
Just received my v2. Some formers needed more glue, but overall, not any different from Boomerang quality. I am also happy as the vinyl decals could be easily removed. I fancy a Finnish AF version. The hinges changed to ca ones as I've happily used them.
The undercarriage is quite lightly done, but lets see it probably works fine.
Overall impression is positive, but the main lg blocks seem to be balsa-why? Those will have to be changed. The nose lg blocks are painted so its more difficult to identify the wood species. Probably the same soft wood.
Tuomas
Old 08-17-2012, 04:46 AM
  #2484
Stobe777
Stobe777's Avatar
Double post
Old 08-17-2012, 11:44 AM
  #2485
DrYankum
Can anybody instruct me on how to upload my recovered V2 onto the thread. I've put the pix in my gallery, but dont know what to do from there.
Old 08-17-2012, 01:49 PM
  #2486
BaldEagel
BaldEagel's Avatar
Don't use quick reply, use reply on the top of a post, at the bottom you will see the upload icon.
Mike
Old 08-17-2012, 02:02 PM
  #2487
DrYankum
Decided to recover my V2 Tornado. Not only was it getting ratty looking, but with the grey bottom in a grey sky, it was difficult to track the plane
ID:	1792876   Click image for larger version
ID:	1792877   Click image for larger version
ID:	1792878   Click image for larger version
Old 08-17-2012, 02:23 PM
  #2488
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
Looks good Dr
Old 08-17-2012, 02:34 PM
  #2489
DrYankum
Biggest problem was matching the cub yellow ultracoat with spray in a rattle can. Finally decided on Testors yellow which is very close. Problem is that it is not jet A fuel proof. Kryon clear and Top Flite clear react. (wasn't I glad I tested it on the bottom hatch first). Finally, poloyurethane clear did the trick
Old 08-17-2012, 05:21 PM
  #2490
TUMBLER
My Feedback: (13)
I glued blocks to the stock servo mount/hatches and screwed servos to the blocks. I would like to see how guys are doing the linkages and the control horn placment for the rudders and the alevato on V3 though. The only instructions out there only show earlier version with exposed servos.
ORIGINAL: BaldEagel
Mike
Old 08-17-2012, 05:23 PM
  #2491
TUMBLER
My Feedback: (13)
ORIGINAL: BaldEagel
Mike
Old 08-18-2012, 02:53 PM
  #2492
TUMBLER
My Feedback: (13)
I am using the springair retracts and struts. is it normal that half the wheel hangs below the bottom of the fuse??
Old 08-18-2012, 02:55 PM
  #2493
TUMBLER
My Feedback: (13)
Old 08-19-2012, 06:50 AM
  #2494
Ramz
Ramz's Avatar
Yes that is normal for some of the wheel to hang down. You won't notice it in the air.
Old 08-19-2012, 08:55 AM
  #2495
phantom_najd
ORIGINAL: TUMBLER
Try washers under the lading gear to tilt it a little bit outward when gear is down (you need to use two or three thin washers) and the gear will go full inside the well.
Azzam
Old 08-19-2012, 09:36 AM
  #2496
ahmad520
-deleted-
Old 08-19-2012, 09:48 AM
  #2497
phantom_najd
ORIGINAL: phantom_najd
ORIGINAL: TUMBLER
Azzam
I mean inward.
Azzam
Old 08-19-2012, 11:29 AM
  #2498
Xairflyer
Xairflyer's Avatar
You can also crank the wire back like a trailing link so it will go in further, also help it track better, or you could make your own trailing leg not that difficult
ID:	1793306   Click image for larger version
Old 08-21-2012, 11:43 PM
  #2499
Stobe777
Stobe777's Avatar
Ok, replaced the landing gear mounts in the wing with proper thick plywood blocks...much better now! But the elevator, is it really supposed to be glued in place? The transporting and storing the model will become difficult.
TP.
Old 08-22-2012, 12:12 AM
  #2500
BaldEagel
BaldEagel's Avatar
Yes glue it in place and make a spreader plate to bolt onto the booms when removed from the airframe to prevent transport damage.
Mike
