 The new Tornado sport jet >
Old 01-19-2013, 09:47 AM
  #3076
Default RE: The new Tornado sport jet
<span style="background-color: rgba(255, 255, 255, 0);">it was very sad, it's my first turbine and I can buy one of those very cheap. then I look further.</span><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">Thanks Henry</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">Regards Jimmi</span></div>
Old 01-19-2013, 10:42 AM
  #3077
Modellbau USA's Avatar
If there is anything I can do to help you out please contact me direct at
[email protected]<br type="_moz" />
Old 01-19-2013, 10:59 AM
  #3078
The yellow and Blue is awesome I'm going to get one soon
Old 01-19-2013, 01:36 PM
  #3079
Hey guys below is the updated manual for the New Tornado V3. There have been only a few changes in the building process but I hope this helps. The manual will be up on the website in a few hours as well. I am very glad that everybody that has received there New V3 loves it. We spent a lot of time anymoney to send a rep from Modellbau to the new factory for QC. We will be basing somebody over at the new factory permanty in the near future since we will be moving all our production there.
File Type: pdf
Old 01-19-2013, 08:00 PM
  #3080
My Feedback: (57)
Looks good Henry. Quality strong jet, good instructions, & awesome prices! Can't wait to see this thing fly at FJ2013!..
Old 01-20-2013, 10:30 AM
  #3081
The manual is now uploaded on the Modellbau website.
www.modellbauusa.com
If anybody needs any help or advice, please contact me via email or phone.<br type="_moz" />
Old 01-20-2013, 02:37 PM
  #3082
How heavy is the first version #3 with a rabbit 100? Just finished mine and it came out at 17.5 lbs dry.Now if the snow would melt.
Old 01-20-2013, 03:14 PM
  #3083
It always depends you cant just see one number. The main reason is everyone builds completly diffrently. I made several custom tray mounts and reinforsed everything including Hysol on everything but I think your close. Mine was 18.5 pounds with the Rabbit 100 and I also had a bigger ECU battery because the one that comes with it only last for three starts and cool down cycles if its hot out. So 4300 mah ECU, 2 RX batteries 2200 mah each,2 voltage regulators, 2 switches etc. So I think you must be right on. Once I add fuel im around 22 or 23 pounds I think. All I know is now for fun I takeoff just above a stall and violently pitch the nose up at full power and it climbs staight up looks very cool and sounds even better. This plane is so easy to fly its its not funny. Hope this helps.
Old 01-20-2013, 11:37 PM
  #3084
Banned
ORIGINAL: Heliman4213
Ver nice, I know it would add a little weight but it would look nicer with a pilot in the cockpit
Old 01-21-2013, 05:33 PM
  #3085
I know I should put one in soon. Maybe by flying season.
Old 01-21-2013, 05:35 PM
  #3086
Henry,
How many of the new blue and yellow Tornados do you have left? If you dont, when is the next shipment coming in? Are you going to have a special on it at Florida Jets?
Thanks Bob
Old 01-21-2013, 09:02 PM
  #3087
ORIGINAL: funflyerf4
I just finished and test flew a V2 I built for a buddy. Came out 14lb 15 oz with full UAT. Has the Rabbit pushing it along, but turned down to 16 lbs of thrust. This is his first jet so I dont wanna tempt him! Flys great.
Old 01-22-2013, 08:20 AM
  #3088
My Feedback: (9)
Will the original v3 retracts spring air fit in the new v3?
also it would be nice if the horiz stab was removeable for easier transport, or the wings were split farther from the fuse
Old 01-24-2013, 12:41 PM
  #3089
My Feedback: (162)
jonkoppisch's Avatar
mine just came in, WooHoo!
Here's a look at the blue model.
There was a hole in the box but it looks to be ok.
ID:	1843887   Click image for larger version
ID:	1843888   Click image for larger version
ID:	1843889   Click image for larger version
ID:	1843890   Click image for larger version
ID:	1843891   Click image for larger version
Old 01-24-2013, 01:34 PM
  #3090
737Driver's Avatar
That looks nice!! That's what my box looked like, minus the man handle marks on the box. Glued up ailerons and flaps last night, today servo install. I picked up all the recommended servos yesterday, that stung!!! $$$$$$$
Old 01-24-2013, 02:51 PM
  #3091
BaldEagel's Avatar
Guys have a look at the Savox servo's not as expensive as you may think: http://www.cmldistribution.co.uk/cml...tId=0000003924 ideal IMO for the tail servo's.
Or these for the ailerons and flaps: http://www.hobbyking.com/hobbyking/s...=Turnigy%20TGY
Just a suggestion, have not used either myself, but seem to fit the bill.
Mike
Old 01-25-2013, 02:08 PM
  #3092
737Driver's Avatar
Does anyone know if it matters how the control horns for both aileron and flap face the same direction? It looks like in the photo that the flap horn faces the trailing edge of the flap and the aileron horn faces the leading edge.
Tom
Old 01-25-2013, 02:24 PM
  #3093
Banned
ORIGINAL: 737Driver
Tom
The aileron horn must be over the hinge line of the of the aileron and must therefore face towards theleadingedge of the aileron and trailing edge of the wing
The Flap does not need to be over the hinge line and in factif it is back from the hinge line a little it will have more leverage. This is why people sometimes put them the opposite way round
Old 01-25-2013, 02:56 PM
  #3094
BaldEagel's Avatar
The main reason for putting the flap horn facing the TE is to achieve maximum movement of the flap, this will allow the flaps to act as air brakes if needed, so instead of floating on and on with just flaps, you can bring the thing down with air brakes played against power, this combined with reflex ailerons is what most call crow braking, its very effective especially if you don't have a lot of runway to play with.
Mike
Old 01-25-2013, 03:25 PM
  #3095
737Driver's Avatar
Thank you both for your replies. I'm kinda screwed on one wing as I glued both horns on aileron and flap in the same direction, both facing the leading edge. I temp put the flap on, and with the bevel hitting the back of the wing, the horn still doesn't touch the bottom of wing, so if it had to move that much, it could. With the flap in full extend with bevel touching back of wing it's darn near 90 degrees to the surface of the bottom of the wing. I guess I could cut the flap horn off and use another one to face the flap horn to the trailing edge it you guys think that would be necessary?
Thanks!!
Tom
Old 01-26-2013, 12:14 AM
  #3096
Banned
ORIGINAL: 737Driver
Thanks!!
Tom
Post a pic
It doesnt matter which way round they are. It is vital however that the Aileron horn holes are over the pivot point of the aileron
Both flaps are being pulled from the same point (Distance from their pivot line) and with a horn of the same length. this will acheive equal travel on both flaps
Old 01-26-2013, 01:51 AM
  #3097
BaldEagel's Avatar
Tom
Agreed, if you are getting near 90deg's that's enough on the flaps, just make sure on deployment the servo arm is in line with the control rod to take the load off the servo gears, especially if they are plastic.
The aileron horns are all about geometry, as SU says the horn hole you wish to use must be in line with the hinge line if you wish to have equal movement up and down, in the old days when we only used one servo for the ailerons we used to rake the horn forward to give us differential, another birthday today, they seem to come around more frequently the older I get. LOL
Mike
Old 01-26-2013, 02:03 AM
  #3098
Banned
ORIGINAL: BaldEagel
Tom
Mike
Birthday. You need to buy yourself a nice pressie
Old 01-26-2013, 02:51 AM
  #3099
Xairflyer's Avatar
Happy Birthday Mike
Old 01-26-2013, 03:56 AM
  #3100
BaldEagel's Avatar
Thanks guys, wife bought me a project in France, witch I did not want. LOL.
Mike
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
