Reload this Page >
The new Tornado sport jet
Old 04-17-2013, 03:17 PM
  #3376
colesifer3d314
My Feedback: (9)
Default RE: The new Tornado sport jet
txshan,
  How was the performance with the K100? would you recomend flying it with a K80? or was the K100 the ticket? I ask because im selling the P80 for a better suited motor for my Tornado I baught from Sam. I appreciate any info you can give.
Thanks alot,
Cole
Old 04-17-2013, 06:18 PM
  #3377
joeflyer
My Feedback: (47)
ds,
You shouldn't need a trailer. Mine fits just fine in my Navigator. Your Escalade is about the same size. The trickis to shove it in far enough that you take advantage of the extra width by the rear doors.
I put mysecond row seats down and put it in nose first at an angle similar towhat's in your picture. I have to lift the right wingup as I slide it in until I get past the cargo area. The nose isall the way to the left just behind the drivers seat. The right wing is near the center of the right rear door. It sits there just fine with several inches of clearance all around. I've had my Falcon 120 for 5 years now and put hundreds of flights on it and I've never hadto take the wings or booms off for transportation. It fit in my old Ford Expedition the same way.
Give it a try.
Joe
Old 04-17-2013, 06:29 PM
  #3378
Heliman4213
strange about the fuel issue. I have the Jet Central Rabbit. I fly aggressive for 7 minutes and have 2 go arounds if needed. I have been told this engine is very fuel efficient. My timer is set for 7 minutes and then I get in the pattern and have fuel left when I land for a go around. Less expensive engine may have less in some areas? I think its not good that all the components are internal. Everytime you have an issue the en goes back, lost flight time. Unless the company is letting the user take apart the engine? Jet Central will try to troubleshoot over the phone and send you what you what you need if not you send it in. Not sure about King Teck. Jet Central s turn around time isn short. The other big company has made people wait for 3 months for a simple bearing change, not good.
Old 04-17-2013, 07:23 PM
  #3379
TUMBLER
My Feedback: (13)
I have a Mountaineer which is the same as an Explorer. I leave the wings on but have to take the booms off. It is a tight fit to get it in with the wings on but it fits in on an angle. No idea how it could fit with the booms on.
ORIGINAL: txshan130
Dslivingston,
I know someone who keeps the wings on and transports it in an Explorer I think. He made some rails that he installed in the back of the truck and then places the jet on the rails...that gets him a few inches of space to allow the wings to fit. Not easy, but easier than removing the wings I think..
Old 04-17-2013, 07:27 PM
  #3380
TUMBLER
My Feedback: (13)
That looks like it would fit to me. With the booms off I put mine in and have to tilt it at a 30 degree angle and put a transmitter case under the one wheel. You could probably do the same thing and fit it in your car with the booms on.
ORIGINAL: dslivingston
Well I went to fly my Tornado yesterday and guess what? It wll not fit in an Escalade. Out shopping for a 8 x 18 trailor today.
Do not believe what a salesman will tell you when ordering something. It's really my fault I should have done my own measuring. What the heck ... I needed a trailor anyway.
Old 04-17-2013, 07:37 PM
  #3381
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
Has anyone glassed the wings? I'm wondering what the weight is..
Old 04-17-2013, 08:25 PM
  #3382
BaldEagel
BaldEagel's Avatar
ORIGINAL: joeflyer
I've had my Falcon 120 for 5 years now and put hundreds of flights on it and I've never had to take the wings or booms off for transportation.
Joe
Joe
Are you still flying the Red Bull scheme, I have to say when you did that re-cover I thought it looked really good.
Mike
Old 04-17-2013, 10:10 PM
  #3383
GhostRider 1
The plastic tank holds exactly 74oz. Also BEWARE!!!! if you fly to hard with a K-100 you can and will bend the wing rods!!!! Suggest finding a hardwood dowl to fill the aluminium rod or find a carbon fiber replacements. Looked like a bent wingCorsairaftersome yanking & banking.
Old 04-17-2013, 11:53 PM
  #3384
BaldEagel
BaldEagel's Avatar
Always was a weak spot, in the early days of the Falcon some even had them fail completely in flight, the upgrade was as you say. put a dowel inside the Ali tube.
Mike
Old 04-18-2013, 03:55 AM
  #3385
joeflyer
My Feedback: (47)
ORIGINAL: BaldEagel
Joe
Mike
Thanks, Mike. It's still going strong. I'm waiting for this wet April weather to improve so I can start flying it again.
Joe
Old 04-18-2013, 04:16 AM
  #3386
txshan130
My Feedback: (114)
txshan130's Avatar
Ok...if anyone finds a source or size for the dowel to go inside the wing tube, please post it.  Would like to do this ASAP before we have issues :-)
Old 04-18-2013, 05:31 AM
  #3387
alasdair
alasdair's Avatar
ORIGINAL: uixkes
Hi all, finally my Jet is ready to go. Now only the weather has to improve and I can maiden her.
But spring is definitely around the corner. Unfortunately for this weekend the forecast says 35 miles/h wind [&o]
So, no more excuses. But I am actually looking forward to fly it for the first time.
c u
Ulli
Hi Ulli, where will you be doing the test flight?
Are you going to the Fly-in at Machrihanish on May 4/5 ?
Old 04-18-2013, 06:41 AM
  #3388
BaldEagel
BaldEagel's Avatar
ORIGINAL: joeflyer
ORIGINAL: BaldEagel
Joe
Mike
Joe
Still looks as good as I remember it, or is that an archive pic.
Weather here is about the same, today we have high winds, really played havoc with my casting.
Mike
Old 04-18-2013, 11:12 AM
  #3389
jetflyr
ORIGINAL: txshan130
Take your aluminum tube and go to Home Despot - find one that is close and, if necessary, sand a bit to fit then epoxy into place.
Greg
Old 04-19-2013, 06:14 PM
  #3390
TURBOMC
My Feedback: (7)
Henry I need a little clarification please. I've seen in this forum where P80s are NOT recommended but K80s are highly recommended. Both engines weigh approx 2.9 lbs including starter and the P80 is only about 5/8" bigger in diameter. Aside from the 2-3 lbs more thrust from the P80 is there another reason it is not recommended? Thanks for your advise.
Old 04-19-2013, 07:00 PM
  #3391
colesifer3d314
My Feedback: (9)
ORIGINAL: TURBOMC
pretty interested in this myself..especially since the P100 is a recomended motor on the website at 22lbs of thrust
Old 04-20-2013, 06:03 AM
  #3392
Modellbau USA
Modellbau USA's Avatar
The P80 or now the new P90RXI is a great turbine. The reason we don't reccomend it is due to its size. We make the motor mounts to fit the smaller diameter turbines. It's not a thrust limit but size limit. We have had several customers use P80's but they have had to make a customer motor mount.
Old 04-23-2013, 05:43 PM
  #3393
Heliman4213
Henry,
Do you have extra gear for the Tornado in stock? How much? If not when will you have some?
Old 04-24-2013, 08:30 AM
  #3394
Gixxy
My Feedback: (18)
ORIGINAL: Heliman4213
Henry,
Could always get them directly from Bill @ spring air if they aren't in stock
www.retracts.com
Old 04-24-2013, 10:37 AM
  #3395
Heliman4213
what about the struts?
Old 04-24-2013, 10:48 AM
  #3396
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
its sold as a combo wheels, brakes, retracts, struts, tank and I think tubing and Ts cant remember
Old 04-29-2013, 08:31 PM
  #3397
Backplate
Hey Guys,
Can any body tell me or put up pics of how to set up the canopy to the plastic tub, & how they hold it on to the fuse, I'm sure this has been shown on this site before but there is so many pages of ref to the Tornado it would take me days to go through it to find the page on fitting canopy to tub / fuse.
Thanks.
Old 04-30-2013, 02:50 AM
  #3398
txshan130
My Feedback: (114)
txshan130's Avatar
Go to the top of this page and select "Gallery" .  You will then see all the pics ever posted.  Much easier than sorting thru 150 pages of posts.
Old 04-30-2013, 06:25 PM
  #3399
emart
quick video of my Tornado
http://www.youtube.com/watch?v=Cr489vQ8qKk
Old 04-30-2013, 06:33 PM
  #3400
txshan130
My Feedback: (114)
txshan130's Avatar
Here's how we did the canopy...used the included latch. All very secure.
ID:	1877865   Click image for larger version
ID:	1877866   Click image for larger version
ID:	1877867   Click image for larger version
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
