Reload this Page >
The new Tornado sport jet
Old 04-30-2013, 07:20 PM
  #3401
txshan130
My Feedback: (114)
txshan130's Avatar
Default RE: The new Tornado sport jet
From last weekend...
ID:	1877939   Click image for larger version
Old 04-30-2013, 07:22 PM
  #3402
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
What field is that Brian?
Old 04-30-2013, 07:23 PM
  #3403
txshan130
My Feedback: (114)
txshan130's Avatar
Scobeeeeeee....
Old 05-04-2013, 12:15 AM
  #3404
Backplate
Thanks Emart for the pics of the canopy installation.
Old 05-04-2013, 02:14 AM
  #3405
txshan130
My Feedback: (114)
txshan130's Avatar
Actually those were ours :-)
Old 05-24-2013, 03:10 AM
  #3406
dcala
Hi All About to start build on v3 tornado and have question on installing the fuel tank. I notice that some people had to trim one of the bulkheads so that the fuel tank can be installed as far rearward as possible how is the tank secured? The directions says to use goop do you just blab the goop on the bottom of fuse Thanks Bill
Old 05-24-2013, 03:33 AM
  #3407
2FAS
dcala, I built the V3 with the composite booms and I did not have to remove any of the bulk heads for it to fit. The tanks stops against one of the last bulk heads on the turbine end and I created a tray that rest against it on the stopper end. My tank is removable if needed.
Old 06-20-2013, 05:12 AM
  #3408
chrispol
My Feedback: (9)
What I did is put a lip in front of the canopy and drilled the back for a single bolt into a captive nut nice and easy
ORIGINAL: Backplate
Hey Guys,
Can any body tell me or put up pics of how to set up the canopy to the plastic tub, & how they hold it on to the fuse, I'm sure this has been shown on this site before but there is so many pages of ref to the Tornado it would take me days to go through it to find the page on fitting canopy to tub / fuse.
Thanks.
Old 06-20-2013, 05:16 AM
  #3409
chrispol
My Feedback: (9)
After much reading and literally sitting on this model for a year i decided to complete the build, and one of the issues is 8 screws for assembly at the field ... not an attractive option, but there is a way to narrow it down to 4... i replaced the wing bolts with shoulder bolts groved a slot and epoxied collars into the fuse, slip the wing it tighten the collars, take less than a minuite, picked up this hint off someone building the f-86
ORIGINAL: dslivingston
I could remove the wings but that seems to be a real pain. The horizonal stab is glued.
Old 06-22-2013, 05:31 PM
  #3410
chrispol
My Feedback: (9)
I saw someone did a single control line for the steering instead of a pull pull, wondering if anyone has pics? mine seems to be rubbin on the front wheel well alot
Old 06-22-2013, 07:02 PM
  #3411
txshan130
My Feedback: (114)
txshan130's Avatar
use rubberbands to keep them taught
Old 06-22-2013, 11:58 PM
  #3412
BaldEagel
BaldEagel's Avatar
Heat shrink the long part of a cable tie to the cables, it will pull them apart when retracted and offer practically no resistance to the retract mechanism.
Mike
Old 06-23-2013, 03:08 AM
  #3413
Xairflyer
Xairflyer's Avatar
As Mike suggested cable tie method works good but personally never a fan of working the steering with "two bits of string". One thing makes me laugh guys spending £500+ on retracts then working the steering with string!
I have used this modification on a few conventional push/pull systems, you need to make a right angled steering arm, and fit to it one of those aileron torque rod eyes so it can slide on your steering arm. Reason for this is when the leg retracts the pushrod is not effected.
You can then simply fit a clevis/ball link to your pushrod and mount your servo where you want. I normally try to mount close to the leg but in case of the tornado it can be in the same place on the equipment tray.
Second pic is off similar fitted to elan but shows leg retracted
ID:	1894242   Click image for larger version
Old 06-23-2013, 09:09 AM
  #3414
Dieselman1220
My Feedback: (25)
That's really cool xairflyer i just use some rc car 72mhz antenna tubes and run the wires through there then just epoxy them somewhere they won't be in the way.
Old 06-24-2013, 08:41 AM
  #3415
chrispol
My Feedback: (9)
Well seems like i had too much tension finally on the pull pull wires, stopping the gear from locking in flight. Lets just say steering sucks on landing without a nosewheel.
Anyone know if the v3 retracts will fit the "v3+" or f86? or if they can be cut doen to fit?
Old 06-24-2013, 09:49 AM
  #3416
Dieselman1220
My Feedback: (25)
You may be able to cut them but the new v3 does use the shorter struts
Old 06-24-2013, 10:00 AM
  #3417
myersflyers
My Feedback: (33)
Where can I get a clear canopy that fits the Tornado/Falcon120?
Keith
Old 06-24-2013, 11:38 AM
  #3418
phantom_najd
ORIGINAL: myersflyers
Keith
Try this [link]http://www.modellbauuk.com/falcon-120-replacement-canopy-191-p.asp[/link]
Azzam
Old 06-25-2013, 02:22 AM
  #3419
myersflyers
My Feedback: (33)
Thanks Azzam, Appreciate your help on this!
Old 07-26-2013, 06:29 AM
  #3420
737Driver
737Driver's Avatar
Hey guys!
I've hit the wall, not literally, but figuratively on my build and don't see me finishing my project. The only thing I have left to do on my Tornado V3 is install power system, fuel lines and air lines and that's it!!! The nice landing gear is installed, the K100G is mounted, that only has maybe 15 minutes of run time on it, servos are installed and wired. It would take maybe a good long day or 2 to finish this bad boy to get it flying. I just don't have the time nor ambition to see it through, don't even know why I bit on the Christmas special but I did and now it's just sitting there. If anyone is interested in a smoke'n deal on this bad boy, I'm willing to cut it loose for a one time low price. Let me know!!
Tom
Old 07-26-2013, 06:38 AM
  #3421
txshan130
My Feedback: (114)
txshan130's Avatar
No...don't give up Tom! Driving that FF around too much I guess ...
Old 07-26-2013, 06:47 AM
  #3422
737Driver
737Driver's Avatar
Yup, giving up! I have enough planes as it is. Yeah, driving the new toy around, the Tornado won't fit in it!!!!
Old 09-12-2013, 04:43 AM
  #3423
ravikoth
Hi Guys,
Long thread thisn one is, read through it all.
Just had a quick question,
Once Flaps are deployed what is the effect on Pitch?
Is a significant amount of down elevator reqd?
Cheers
RAvi
Old 09-12-2013, 05:07 AM
  #3424
rpat
I have the original version ans when I deploy the flaps I don't notice any big difference in attitude. The nose for the most part stays where it is pointed.
Old 09-12-2013, 05:11 AM
  #3425
Xairflyer
Xairflyer's Avatar
It will depend on amount of flap you have, I experimented with amount of flap deflection that worked for me, I have about 5mm down elevator but also have aileron reflex (crow braking) as well.
I found it takes quite a few flights to get it all setup right
