The new Tornado sport jet
#902
NJ
Im getting ready to mount my uat with a P-70 in the back would the uat be better in the front by the air tank or back by the main tank for balancing?
Thanks Frank
Thanks Frank
#903
ORIGINAL: funflyerf4
Thanks Frank
Thanks Frank
Greg
#904
My Feedback: (25)
Kenrico: Can you post a couple of pix showing your canopy attach method. I understand the system...it's the same as my Flash...but the pix in the manual are not clear especially the rear attach point. I just want to save some time and potentially copy your method. Thanks.
Mike
Mike
#905
NJ
Finally got mine done with a P-70 it came out at 15.7 lbs dry.My throttle trim on my trans. crapped out wile setting up the radio so off it goes to get fixed.For the cannopy I put a piece of wood in the front to slip under the fuselage and I added a piece of wood in front of the former by the rear and put a screw in from the top of the canopy.I will try to get some pictures up soon.The cg came out at 1.10 lbs on the scale.
Frank
Frank
#906
Finally got mine done <SNIP>The cg came out at 1.10 lbs on the scale.
Frank
Frank
If it is the later, you are good to go (it's where mine is) you'll just need a fair amount of push when inverted.
If it is 1.1 ..... you will be grossly tail-heavy.
Greg
#909
It is 2 oz nose heavy
Greg
#912
My Feedback: (7)
WA
Ok... how bout some detailed flight reports already!!! ;-)
I'm hearing it flies like its on rails, and from Henry's few vids looks like it, but I'd like some comparison flight reports... like to a BVM Bobcat? or a Falcon?
Z
Z
#913
It seems like this thread just died off! I would have thought for sure that atleast one person would have a flight report and maybe perhaps a vid or 2...common guys! [8D]
#914
ORIGINAL: Ramz
I had to drive 835 miles to get my flights!
Greg
#915
My Feedback: (7)
WA
ORIGINAL: jetflyr
Umm....It's February and most of the country (northern 2/3 of the continent?) has crappy cold and windy weather.
Greg
ORIGINAL: Ramz
Greg
How bout an answer from the other 1/3 of the continent... you know in the southern half;-)
Z
#917
And the worst part is that their is 4 ft of snow outside my door!!! Stupid winter. Oh well...should give me lots of time to get my Tornado setup properly.
#918
I maden mine last weekend, sorry no video
It flew very well and very stable
Only modifications I made were in the struts, I shortened the front strut by 3/4" so the plane was level wile sitting on the ground, I was afraid that the take off may be abrupt but actually it takes off by itself
For does how are thinking in bigger turbines please don't, mine has a Bee II but I'm flying at 7500' over sea level, that means that the turbine looses more than 30% of the thrust and the airplane lift is affected in the same way and I was cruising at less than half throttle, full throttle passes were very fast (faster than I felt comfortable) and it can clime forever
CG and throws were the recommended and they are perfect for first flight
Sorry for the spanglish
#922
oh man! that's bad, Did you glue the Stab to the Booms.? if not maybe you could get a new Stab from Henry. What engine is it? if I may ask.
#925
Wow that sucks. I was wondering about gluing in the horizontal stab for that very reason..I know in the instructions they show you to glue the stab to the booms. Has anybody flown the Tornado without gluing the stab on? Looks like I will be building a start tube like this one: http://www.troybuiltmodels.com/ns/im...rbine-tube.jpg
