The new Tornado sport jet
#1103
The mini-T should be out near September. We are still working out a few bugs on the airplane so it is not ready. We are still debating if we will make it fully composite. I will give more info soon
#1104
My Feedback: (7)
WA
This may seem like a silly question as it pertains to the Tornado "build", but can someone tell me where all the servo extensions are supposed to go to?
I purchased the servo set with my Tornado, and it came with all the servo extensions, but before I put the wrong length extension in the wrong spot I was wondering
if guys that have their Tornado's airborne could help me on this? There's lot's of them, ie, 6", 8", 12" 18" and like three y's? I figure the y's go to the ailerons, rudders,
and elevators, but what length extensions go where? I know there are 5 18" extensions. I've already used two of those for the aileron servos, but now I'm thinking I messed up and
should be used for the elevators or rudders (boom servos)? Help!
... and thanks
Z
BTW, nothing was mentioned on this in the manual?
... and thanks
Z
#1107
Yes we do sell the tanks, you can purchase the 80oz fuel tanks and any another part for the Tornado directly from us.
In regard to the extensions I thought they were self explanatory because they were made exactly to length. Jaime please call Alberto at 954-445-2197 and he can help you out with any questions you have. I am currently down in South America and will be back in a few
#1111
Those are some great photos Rod! Thanks.
Mine is completed as well...just waiting for some nice weather. It will be my first turbine flight ever so I am pretty pumped.
#1113
Below are the 3 schemes that are now currently offered for the TORNADO. The airplanes will be here the in early July, we will start pre-sales for the kits again in May.
#1116
I just got to fly mine and it is amazing. I had a Falcon and it was no were near as stable as this thing is. A+++ for a great job, I cant wait till the F86D come out I want one.
#1117
Very nice work on the video. It looks like it flew really well.
I just maidened mine. Both main gear blocks fell out upon landing and tore the bottom of the wing up pretty good. The landing was a bit rougher than what was in the above video. For the 4 minutes it was in the air it seemed to fly ok but the landing gear mounts are garbage. Their was little to no glue holding them in (same with the nose gear but i was able to pull them out and re-glue them). The front gear blocks were the only ones that held...surprise surprise.
Both of the main wheels seized up aswell during my first taxi tests. I had to remove both of my main wheels numerous times and file away some of the hub so they would spin freely. The machining tolerances were quite a bit off.
It was a bad day. I am not 100% happy with the Tornado at this point.
#1118
ORIGINAL: Ramz
I hadn't flown (weather has sucked) since February, so my touch and goes were not the best, but she really slows down well for a full stop.
My gear blocks weren't great either, but a bit of Hysol did the trick.
Hang in there!
Greg
#1119
ORIGINAL: jetflyr
Yeh, it fly's great, far more stable than the Falcon I had.
Hang in there!
Greg
ORIGINAL: Ramz
Hang in there!
Greg
#1121
Ramz I agree with you but there kits have been very good. I purchased 3 of there kits 2 Tornado's and 1 MB339 and they all were great. I have had a few very hard landing on my Tornado while learning jets and it took a lot for those gear to break out. You might have just gotten one that unfortunately did not get glued correctly that might happen when mass producing large number of planes like this one.
#1122
ORIGINAL: david robinson
#1123
OK
I had the same problem with my Boomerang Sprint! I must have broke the gear out at least 5 times before I finally got them glued in well enough to stay. Of course it didn't help when I froze on the sticks and forgot to pull up on my first take-off! Then I forgot that I had brakes and ran it into the tall grass around the asphault runway. It was quite a stupid thing but I was nervous and went brain-dead! I knocked all three gear out and tore up the bottom of the wing. I eventually got enough glue and bracing around the blocks to hold them in well. There are always things that aren't built well enough on these arf's. I think the quality department in China isn't what it would be here in the states and if it was we couldn't afford to buy these things! Don't let a little hickup ruin your fun though. All the guys I fly with have broken out gear so they just welcomed me to the club!
Chris
Chris
#1124
ORIGINAL: chris1971
Chris
Chris
I am still kind of bitter because I have been waiting for that moment since July 17th, 1996 which was when I first saw a turbine powered F86 at a FF. It was my first turbine flight ever and the first flight on the Tornado...it would have been nice to land it in one piece but it ended up in failure. Kind of took away from the moment but it will fly again and it will be a success. The only damage to the airframe was where the gear pulled out so it's not like it was slammed into the ground.
It is impossible to build them so that the gear will never pull out but a few basic, very inexpensive steps in the construction process would have helped. I also noticed that the landing gear blocks were made out of balsa....BALSA!! ARGH! What were they thinking? At the very least they could use something harder than balsa sticks. It would also be nice to see some 1/8 ply doublers on the 3 ribs that the gear blocks attach to. I doubled up mine while I had it apart.
