The new Tornado sport jet
#2076
My Feedback: (46)
ORIGINAL: LittleBob
For petes sake we are talking about a fuel tank in a simple and cheap model. Keep a sense of proporting and dont go over the top.
Before long you will be holding your turbine on with high tensile bolts when a simple wood screw will do
#2077
ORIGINAL: LittleBob
Mike
#2078
ORIGINAL: BaldEagel
Nice generlisation Dennis, but I certainly would not hold any turbine over a 120 with wood screws.
Mike
ORIGINAL: LittleBob
Mike
#2079
ORIGINAL: LittleBob
Folk are very strange at times but we all set our own priorities and standards however silly they may seem to others.
#2080
Wood screws are absolutely fine, as long as the application is appropriate. Flew MANY years with 30 lbs thrust turbines in an Isobar and HotSpot with wood screws. They, of course, need to be sized appropriately and need to go into stout enough material and be locked in with CA adhesive.
#2082
ORIGINAL: Woketman
#2083
I concur, nothing wrong with bolts and lock nuts. Have used that many times too. But the point is no one should make statements like "I certainly would not hold any turbine over a 120 with wood screws". Little wood screws into inadequate material? Yeah, that is bad. But properly sized ones into the right material, a very good installation.
#2084
Banned
Regarding a 30 lb turbine and say a 4 mm wood screw
I set you this challange. Screw the screw into a piece of wood up to the head but with a piece of wire in a loop around it. Now take some weights and hang them off the wire. If that wont support over 50 + pounds I will eat my hat if indeed I had one. It does of course assume a decent piece of wood but then that should also be the case with the bolt solution.
Now that is just one screw and with our turbines we generally have 4 screws.
Any one think this screw will not support 50 lbs
#2085
Banned
ORIGINAL: Woketman
#2086
Banned
ORIGINAL: Woketman
Duplicate. Lots of R/C U problems. Why don't they ever fix it???
They used screws instead of bolts and it fell off and broke
#2088
ORIGINAL: LittleBob
And you can easily remove the turbine if you need to. And no it will not remove itsself as I can hear someone saying
ORIGINAL: Woketman
#2089
ORIGINAL: Woketman
I concur, nothing wrong with bolts and lock nuts. Have used that many times too. But the point is no one should make statements like ''I certainly would not hold any turbine over a 120 with wood screws''. Little wood screws into inadequate material? Yeah, that is bad. But properly sized ones into the right material, a very good installation.
Mike
#2090
ORIGINAL: BaldEagel
What have I ever done to you to warrant the personnal attack?
Mike
ORIGINAL: Woketman
Mike
#2092
ORIGINAL: Woketman
Huh? What personal attack?? Feeling a bit paranoid????
#2095
NC
ORIGINAL: Woketman
Yes, but clearly NOT an attack. An attack is if I call someone a dumb_ss!!!
