Ultra Bandit powerplant????
Guys,
Looks like I could be getting into an Ultra Bandit!!
Now, I have a P160SX and a P200SX. Immediate reaction would be to go for the 200SX BUT I wonder if anyone has experience of a lighter 160SX setup? I know a lot of people think the Ultra Lightning is better with the lighter 160. As similar sized models I wondered if this held true with the Ultra Bandit?
I'm really not bothered about going for 250mph+ if that helps with any feedback....
What do you think?
Cheers
Mark
What do you think?
Cheers
Mark
My Feedback: (61)
TX
RE: Ultra Bandit powerplant????
i asked the same question directly to BVM when i purchased mine, they said that if you went with no cockpit and the small tanks that a 160 would be OK, but stick with a 180 or 200. mine has a 200SX.
when the UB was first introduced they has a "small engine" and a "big engine" version. they now simply have the big engine version.
P200 would be good IMO, a JC Mammoth was going to go in it, Ive been really impressed with this engine and that's from a die hide JetCat user.
Hey Mark,
Definately the 200SX. I use the big saddle tanks (2.6 lt each) and they connect directly to the high flow UAT, and the center tank is used for my smoke system.
Cheers,
Darryl
Cheers,
Darryl
Hey Mark,
In my opinion a "sportjet" needs a big engine!!!!
It makes the airplane much more dynamic in flight.
End speed will never be an issue when going P160 or P200.
Cheers Didier
Cheers Didier
George,
I believe there is a bloody expensive install kit needed that differs between engines?
I think the model I have my eye on is setup for a 200SX already so I'll go that route. Seems to be everyone's opinion too. I can always dial the 200 down at first and then crank it up although it is so unlikely I'll mess around doing that I might as well stick the 200 in and go flat out from day 1
Cheers,
Mark
Cheers,
Mark
ORIGINAL: schroedm
I can always dial the 200 down at first...
Cheers,
Mark
Cheers,
Mark
PS: where do you get a decent FOD screen for the 200SX from ? The one I got from JetCat looks like *****....
Yes Mark,
The P-180 was in my UB for the first 15 flights or so, then I put in the P-200 Narrow Nozzle (my Skygate Hawk has the P-200SX).
I also retrofitted a P-200SX into Greg's UB.
It's definately the way to go as the 200SX has similar thrust and acceleration to the AMT Olympus HP.
Theese high thrust turbines are very well suited to the UB handling and flight characteristics.
Cheers,
Darryl
Cheers,
Darryl
FL
ORIGINAL: kirkj
when the UB was first introduced they has a ''small engine'' and a ''big engine'' version. they now simply have the big engine version.
I'd also be interested in length of flight time with the P200SX and both the standard fuel system with and without the centre tank being used for fuel.
FL
I don't know of an Ultra Bandit with the small fuel system. (Although there must be one or two).
Down here (Southern USA) everyone uses either a P-180 or a P-200 and the large fuel system.
Hi,
The Ultra Lightning have the same size but the weight is pretty much different. The Ultra Bandit is much heavier that the UL.
Don`t think more about it put the bigger engine inside the Ultra Bandit...Came on man!! This plane must be the fastest on the airfield!!!
Have fun,
Raúl
Have fun,
Raúl
My Feedback: (15)
Just wondering if feelings have changed? I heard that rob lynch made the 160 look pretty good!
I am setup for 200 with tanks and bypass but could still be swayed to use my 160sx for the light loading...
Is everyone running a fod screen within the bypass/200 setup without any trouble?
I always like to use one.
Dave
Has anyone tried a 160 in the 200 bypass and tailpipe setup?
Just curious...
Dave
Just curious...
Dave,
Rob Lynch is using an evoJet 160 with the large bypass system. If you've seen it fly, you know it was a rocket ship. Most could not tell the difference between the evoJet 160 and the UB's flying with a 200. I'm sure you'll see it in the vertical eventually, but the bottom line is, I don't think you be upset either way. A little less thrust, a lot lighter plane, lower wing loading, lower landing speeds. All around a good move.
Chad
Chad
ORIGINAL: ddennison
Dave
Just curious...
Dave
Just curious...
My Feedback: (15)
Thanks Chad,
I sent Rob a note but have not heard back yet...
Do you know which fuel system he is using? I am inclined to use the two main tanks (5.2L) only and not header if I go to the 160...
Thanks to all who are sharing their ideas here. My only other concern is to check with BVM of course since they seem to suggest the smaller bypass with the 160.
Dave
Dave
Sorry Dave and Andrew,
I didn't see your questions until now and haven't been to RCU for a while.
My UB flies for 10 min on the Large Fuel Cells (2.6 liters each), and the Center Tank is used exclusively for Smoke Oil. If I push the envelope really hard and end up using a High Power setting then I fly for 9 min.
Regards,
Darryl
Regards,
Darryl
Dave,
I know that Rob much prefers the large bypass system, and credits that with the success of the 160 performing so well in the UB. His plane has the small fuel cells, but you could easily run the large fuel cells and just not fill them. Personally, to do it again, I would just build my UB with the small fuel cells, regardless of which engine. I could easily get over 13 minutes with a 200 and large fuel cells. The lower fuel consumption of the 160 and lighter weight would almost make up for the lost fuel capacity of the larger cells.
Get the big bypass and small fuel cells.....you will like the finished product.
Rob will also be receiving our new evoJet 180 next week. This engine is the same size/weight of our 160, with a larger compressor and more efficient turbine stage pushing 41 pounds of blow. THIS will really be the ticket, taking advantage of the same size/weight savings, fuel economy, and spool up times!
Chad
Chad
ORIGINAL: ddennison
Thanks Chad,
Dave
Thanks Chad,
Dave
ORIGINAL: darryltarr
Regards,
Darryl
Regards,
Darryl
i personally saw the switch that rob did on the u b and we thought that the smaller engine evo 160 kept up quite nicely with the larger jet cat previously installed make lighter fly harder
florida jets this u b was definitely a sight to see
evo 160 just a thought
