The Aermacchi MB339 is here agian
#251
RE: The Aermacchi MB339 is here agian
Try to keep one
i think it will fun and very easy to fly(i hope)
today i assambled the elevtor
i installd in both side 5 kilo digital metal gear slim Graupner servo it was not easy to do it took some time but its look great
here are some pictures
#255
I painted the front wood parts with gray wood p[aint to protect it from water
then i put the nose weal in plase with four 3mm screws with wood nuts
i use for the stearing Hitec645 metal gear servo
#256
then i went to the rear side of the fuselage to assemble the JETCAT P80 in place with the tail pipe
attach some picture
attach some picture
#258
Banned
1 Post
Zeev
Did you get an instruction book with this plane. The one for download on the various websites is very old. If you got one are you able to PDF it and upload it here. I should have my plane in a couple of weeks
Regards
Dennis
Regards
Dennis
#259
Dennis
I have got no instruction book with this plane
that why i start to upload picture to help you all
I need some help with the cockpit i do not know how to make it
do you have some pictures from other MB'S
#260
Banned
1 Post
ORIGINAL: zeev barnes
Dennis
Dennis
Regards
Dennis
#266
Banned
1 Post
Well acording to the Modelbau UK website the stock of the F86, MB339 and I think Tornado's were supposed to arrive today. Havnt received and e mail etc so not sure if they arrived ?
Dennis
Dennis
#268
Banned
1 Post
ORIGINAL: BaldEagel
Dennis
I know its a very old fashioned and outdated idea, but there is the possibility he may answer the phone.
Mike
Dennis
Mike
We aint got them things in the Village I live in. We only just got electric light a week ago and that has confused us all . Had the internet for 20 years though
Dennis
#269
I just got my MB339 a few days ago and will be installing a P80 in the jet. I am concerned that the supplied fuel cell is not big enough to handle flights longer than 5 min with this turbine.
Any suggestions on who makes a larger fuel cell for this jet?
Would really appreciate the help!!!
Luis
Luis
#270
Banned
1 Post
ORIGINAL: toto_sal
Luis
Luis
What volume is the supplied tank ?
Dennis
#272
Banned
1 Post
Hi
THE FUEL TANK IS ABOUT 2.8 LITER
ZEEV
Hi
ZEEV
That is a big tank and should be plenty for a P80 if you use throttle management you should easily get 6 + Mins
Dennis
#273
My Feedback: (10)
NV
My 339 is on its way. Going to do a custom scheme...powerplant will be evoJet XXX. I plan on constructing wip tanks, as well as main and nose doors. Ventral fins are on the list too...
Should be a good project.
Can anyone comment on the landing gear being sold for this bird, quaility?
Thanks!
Thanks!
#274
I just started to build mine now, this is an early production kit, late December 2010. The instructions are a little weak, I don't need a lot info but some critical stuff is missing, for example how and where to mount the pipe??? anyone who has proper info that would be great.
The mounting plate rails for the front gear were not glued, there was glue but it missed the rails that go from former to former, the gear block was only glued on one side. If you have one of these kits I would strongly suggest that you check this area. I replaced the gear block and the 2 rails that go from former to former with better wood and hysol'd them in place. (these rails were pulled out by hand without any damge to the plane)
The troybuilt site states HS5645 servos for the elevator....not even with a shoe horn will these fit, you need a mini servo to fit , 15mm thick is tight, JR3421 or Futaba 3102 I believe, both rated at +/- 64oz
I have installed Model Avaition Products gear in it and Behotec struts, these fit nicely. the only thing for the front is to mill down the mounting tabs a little as they are a tad wide. the front grear is direct drive with a push rod so no wires:-)
Ill try and post some pictures of what I have done soon
Angus
Angus
#275
Hi Dave
Do you have plans for the cockpit?
please post some pictures
Hi Angus
about the tail pipe you can see some pictures that i post
i glue two pices of wood wish 30 min epoxy on both side of the tail pipe and with servo screws i fix it to place
Hi Angus
