Reload this Page >
Yellow Aircraft F-22 ARF Assembly Thread
Old 01-28-2011, 10:53 PM
  #51
Shaun Evans
Shaun Evans's Avatar
Default RE: Yellow Aircraft F-22 ARF Assembly Thread
Hi,
Ian, I forgot to do that while I was in my shop today. I'll do it tomorrow for sure!
Old 01-28-2011, 11:21 PM
  #52
Shaun Evans
Hi,
Got some more work done today on this bird. As previously stated, space is at a premium in here. I've got a lot of stuff to install, so I spent a little extra time trying to plan this out. I decided to add an extra tray above the nose-gear mount. This tray will hold all three valves (canopy, gear/doors and brake valve), the valve servos, the UAT and the gear fail-safe. It rests atop a couple of hardwood standoffs and mounting tabs glued to the existing nose gear plate and former.
Instead of the horizontal accessories trays called for in the kit (and, irritatingly missing from this ARF), I made a vertical tray on the port side for the engine doo-dads. There are still batteries and a receiver to be situated. We'll see what happens! As long as everything is easily accessible to the customer, I'm happy. I plan to make sure that the valves are plumbed so that they won't need to be fiddled with once stuffed in there, but the batteries and fill-valves need to be handy.
ID:	1554926   Click image for larger version
ID:	1554927   Click image for larger version
ID:	1554928   Click image for larger version
ID:	1554929   Click image for larger version
ID:	1554930   Click image for larger version
Old 01-29-2011, 07:28 AM
  #53
tp777fo
My Feedback: (28)
tp777fo's Avatar
Shaun,
Your trays will actually be easier to access and give you more room than the stock trays..Good Idea!
Old 01-29-2011, 10:41 AM
  #54
Shaun Evans
Tom,
Thanks. How did you come out, CG-wise? Did you have to add any ballast?
Old 01-29-2011, 11:07 AM
  #55
Shaun Evans
Hi,
Here's one with the UAT on....
Old 01-29-2011, 11:31 AM
  #56
Shaun Evans
Tom,
Can you talk to me about your VT mixing? What Tx are you using, and what channels did it all take up?
Old 01-29-2011, 03:51 PM
  #57
ddlstang
Shaun, Are you going with the BVM uat and not the Tom Cook one. Looks really good.
Old 01-30-2011, 09:24 AM
  #58
Shaun Evans
ORIGINAL: ddlstang
Ha!
Funny you should ask.... No, actually, my customer wanted the JMP one, and I forgot and installed the BVM one. I'll have to modify the plate and retro the JMP.
Old 01-30-2011, 09:48 AM
  #59
ddlstang
It's looking great, I like how your'e going to put the engine gear on the side panel.
Old 01-30-2011, 11:09 AM
  #60
tp777fo
My Feedback: (28)
tp777fo's Avatar
Shaun, I use a 12X. I'll try to explain my sick method of programming. There are probably more efficient ways but this worked for me.
Ch 1 - throttle
Ch 2 - horz stab (lt)
Ch 3 - horz stab (rt)
Ch 4 - Rudder (rt)
Ch 5 - gear
Ch 6 - Flaps (w/Matchbox) nd set up on the flap system
Ch 7(aux2) - ailerons (through Y connector and slaved to roll portion of stab)
Ch 8 (aux3) - brakes (prog mix with down elevator)
Ch 9(aux 4 - nose wheel steering (prog mix with rudder)
Ch 10 - Rudder (lt) (prog mixed with rt rudd)
Ch 11 (aux 6) - lt nozzle (prog mix with stab)takes 2 prog mixes
Ch 12 (aux 7) - rt nozzle (prog mix with stab)takes 2 prog mixes
I wanted to use Prog mix to make it like the real Raptor and use crow and split rudders for speedbrakes but the nozzles ate up too many channels and pmix options. When I build the next one I am going to use standard nozzles and use the mixes to set up the speedbrakes. The stabs were set up as a delta wing type to get the required action. The ailerons were slaved to the aileron channel to get the roll. VT Nozzles were slaved with the stabs for both pitch and roll and are controlled by a switch for "on-off" control. I didnt have enough free channels to do independent ailerons, rudders and flaps to get the crow on all. The real Raptor only uses the nozzles in the pitch axis but I wanted both. I rarely use the VT as the jet flies great without it, looks good on the ground though when you taxi out flip the switch wiggle the nozzles. Hope this helps.
TP
Old 01-30-2011, 02:17 PM
  #61
marquisvns
marquisvns's Avatar
Shannon, I thought you said Shaun can't build.....
Old 01-30-2011, 09:06 PM
  #62
Shaun Evans
ORIGINAL: marquisvns
LOL,
He gets quite a bit of credit for work I actually did......
Old 01-31-2011, 06:54 AM
  #63
Shaun Evans
Tom,
Thanks for the low-down on the programming.
Ddlstang,
Here's a pic of the tray with the proper UAT....
Old 01-31-2011, 09:21 PM
  #64
marquisvns
marquisvns's Avatar
Can't trust a word Shannon's saying no more, lol
did you get the 170?
Barry
Old 02-01-2011, 09:36 AM
  #65
Shaun Evans
Hi,
Yes, I got it. It looks great. I'll post pics later today.
Old 02-02-2011, 09:06 PM
  #66
Shaun Evans
Hi,
So the VT Nozzles are installed and working now. Pretty neat. All of the servos are now in and all linkage hooked up. All reinforcements (some peace-of-mind, others just habit) are done. Tomorrow is going to be the situating and final installation of all pneumatic lines for gear, doors and canopy.
There's the K-170 that's going to power this baby. A couple of different views. She's starting to look MEAN.
ID:	1557733   Click image for larger version
ID:	1557734   Click image for larger version
ID:	1557735   Click image for larger version
ID:	1557736   Click image for larger version
Old 02-02-2011, 09:20 PM
  #67
Shaun Evans
Here's a blackberry video of the VT nozzles....
[youtube]http://www.youtube.com/watch?v=oWKGVLGQ0ac[/youtube]
Old 02-02-2011, 11:28 PM
  #68
jedijingle
My Feedback: (45)
Looks Cool and Yes Shaun is quite the Builder.
Old 02-03-2011, 12:05 AM
  #69
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
nice building
maybe the vt nozzles could be mixed like ailevons so they control roll too!?
Old 02-03-2011, 08:09 AM
  #70
Shaun Evans
Hi,
Yes, they sure can. The real F-22 does not use VT in roll axis, so I haven't set it up like that, but if the customer wants VT in roll, I'll program it.
Old 02-03-2011, 08:13 AM
  #71
DelGatoGrande
My Feedback: (23)
ORIGINAL: YellowAircraft
oops missed that
Old 02-03-2011, 10:00 AM
  #72
ddlstang
That's looking good, the VT ought to make for some interesting flying.
Old 02-03-2011, 10:26 AM
  #73
Shaun Evans
Hi,
Thanks. Yeah, should be fun. If it can do half the stuff the real one can, it'll be one hell of a fun-to-fly airplane.
Old 02-03-2011, 11:30 AM
  #74
SDCrashmaster
SDCrashmaster's Avatar
Likey!
Old 02-03-2011, 01:47 PM
  #75
marquisvns
marquisvns's Avatar
Shaun, this looks too much fun, what's the price for just the VT unit, like the one Shannon's got?
