High Speed Slope soaring 468 mph
Not sure if anyone has seen this article
http://www.rcgroups.com/forums/showthread.php?t=1383846
and the video
http://www.youtube.com/watch?v=rfoxj...layer_embedded
The speeds make most of our jets look pedestrian. The first part of the video does not capture the plane much but the second part of the video that has slower flight at up to 406 Mph is better.
This plane was fitted with a data logger and measured G forces. Have a look at the file
http://www.rcgroups.com/forums/showthread.php?t=1382898
This shows G forces peaking at nearly 90G and average is about 38G unless I misread the file.
John
and the video
John
My Feedback: (22)
RE: High Speed Slope soaring 468 mph
ORIGINAL: basimpsn
Funny how they still trust 72 Mhz
Why wouldn't they? It was only a couple of short years ago we trusted 72mhz in 20K jets. Just because something new comes out doesn't mean the old technology is no good. I'd still take a 69 Camaro over a 2011 Camaro
My Feedback: (134)
The other good reason for sticking with 72 Mhz on a plane like this is that it is probably mostly carbon fiber to be able to handle the loads. The 72 MHZ antenna plays a little nicer with all that carbon fiber. I am still using 72Mhz on my Stratos sailplane which has a fair amount of carbon in the fuse.
And yes, I would take a 69 Z-28 any day over the 2011 Camero.
My Feedback: (34)
ORIGINAL: kirkj
where does the AMA stand on this, since jets are limited to 200?
ORIGINAL: LGM Graphix
ORIGINAL: basimpsn
My Feedback: (10)
As sailplane flyer, the speed issue with a sailplane is moot once they get out of the rotor on the hill. He can probably hit 200 in a dive if he's flying flat land. The sailplane cannot maintain speed like a jet does. Note also he is flying on a deserted hill, not in a populated area.
And DSing is all about the speed, it's like flying pylon alone. Some people like it, some would get bored with it after a while.
Jeff
Jeff
