Reload this Page >
"ATJ-Flash" with the new ATJ-140SE!
Old 04-02-2011, 11:11 AM
Bob Toilet
Bob Toilet's Avatar
Default "ATJ-Flash" with the new ATJ-140SE!
Hi
Today i have tested the new ATJ-140SE turbine in my "ATJ-Flash"
The new ATJ-140SE was performing superb! Lot`s of power, and very fast acelleration. I am really happy with it. The ATJ-140SE comes with internal kerostart!
I have been flying with ATJ-turbines for 1,5 years with excellent experience: FEJ F-4 with twin ATJ-120TI, FEJ F-14 with twin ATJ-170TI, JL Rafale with ATJ-120Ti etc. C-ARF Flash, first with ATJ-170Ti, now with the new ATJ-140SE. I have the large FEJ F-15 wich i have been flying with twin Jetcat P-160SE, and will put either the newest turbine in the ATJ range: ATJ-180SE! or two ATJ-170TI. I also have a Skymaster F-5 that will have a ATJ-140SE.
Specs:
ATJ140SE Turbine engine Specifications
Dimensions 尺寸: Outer Diameter 110mm; Length: 320mm
Weight 重量 : 1600grams (including starter)
Nominal thrust @ 150C靜推力: 14KG @ 125,000rpm
Idle RPM 低速轉速: 35,000
Idle thrust @ 35,000 低速靜推力: 0.6KG
EGT 噴氣溫度範圍: 650-7800C
Fuel Consumption 油耗: @ max rpm 390 gms/min
Fuel/ oil 使用燃料: Jet -A1 or Kerosene + 5% oil (synthetic turbine engine oil)
Christian
ID:	1587540   Click image for larger version
ID:	1587541   Click image for larger version
ID:	1587542   Click image for larger version
Old 04-02-2011, 11:13 AM
Bob Toilet
Bob Toilet's Avatar
Default RE: "ATJ-Flash" with the new ATJ-140SE!
Specs:
File Type: pdf
Old 04-03-2011, 12:01 AM
andy boy
Default RE:
ILike the ATJ overflow tank. More ATJ pics.....
Old 04-03-2011, 12:20 AM
lavi rider
Default RE:
Hello , in the pictures I see a plug cable .....you specified it has internal kero start...
Old 04-03-2011, 03:55 AM
Bob Toilet
Bob Toilet's Avatar
Default RE: RE:
ORIGINAL: lavi rider
Hi
Yes The SE-series comes with internal kerostart. Mine is the first of the 140SE, and the kerostart was not finish developed, so i got it with gas start now. I will ship the turbine back, end of this month for mounting the internal kerostart.
best regards
Christian
Old 04-03-2011, 04:13 AM
Bob Toilet
Bob Toilet's Avatar
Default RE: RE:
ORIGINAL: andy boy
I Like the ATJ overflow tank. More ATJ pics[img][/img].....
Ok.
Some more ATJ pictures: One of my FEJ F-14 when i first had twin ATJ-120Ti. Needed more power, so i installed twin ATJ-170Ti later. And some of the "ATJ-Flash" with ATJ-170Ti, before i got the ATJ-140SE.
ID:	1587930   Click image for larger version
ID:	1587931   Click image for larger version
ID:	1587932   Click image for larger version
Old 04-03-2011, 06:26 AM
leopaul
Default RE: RE:
Is it a frozen lake where you take off?
Old 04-03-2011, 07:09 AM
Bob Toilet
Bob Toilet's Avatar
Default RE: RE:
ORIGINAL: leopaul
Hi
Yes, it is Lake Bjorkelangen. Located 45 minutes drive outside Oslo, the capitol of Norway. I love flying from frozen lakes!
Christian
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
