Reload this Page >
Oil in jet fuel...?
Oil in jet fuel...?
Old 05-27-2011, 02:29 AM
petera38
petera38's Avatar
Default Oil in jet fuel...?
Hi,
I´ve got a canister (20litres) with A-1 jet fuel with no markings to indicate whether I have mixed in 5% turbine oil or not. The colour of the content is: Light amber yellowish! As far as I know, jet A-1 fuel has no colour, it´s looks like water. I have stored the fuel for almost one year in a plastic canister made for gasoline.
Question is: How do I determine if there is oil mixed in or not? Any simple method to find out?
/Pete
Old 05-27-2011, 02:54 AM
Meesh
My Feedback: (135)
Meesh's Avatar
Default RE: Oil in jet fuel...?
See if you have 21 liters in the canister. You would have added 1 liter to the 20 liters if you added the oil.
Bob
Old 05-27-2011, 03:10 AM
petera38
petera38's Avatar
That´s correct...if I got exactly 20 litres when tanking? The canister can take about 21-22 litres and they are usually rather generous when filling...
If you use turbine oil, which I did, someone told me that the oil will deposit at the bottom after aprox. one day? So all you should do was to shake the canister well and pour some of the fuel into a bottle. Then the oil would deposit at the bottom, after some time!? Worth trying...
/Pete
Old 05-27-2011, 03:46 AM
Henke Torphammar
Henke Torphammar's Avatar
Alot options of where none will give you an exact answer. Also if you fint out that there are no oil in it, would you dare to use yellow fuel for blending with new oil? the yellow color must have came from some where. naaah dump it in your diesel car and buy new fuel for the turbine.
Old 05-27-2011, 04:27 AM
Guillermo Ibanez
Guillermo Ibanez's Avatar
ORIGINAL: Henke Torphammar
Don't take risks. Fuel is not so expensive to risk your turbine.
Throw it away and buy new and mix it with new turbiine oil..
I usually throw away fuel when more than 6 months without use. Although Jet A1 has some additives to avoid micro organisms, after almost a year, one dont know and you can have problems with the UAT and the fuel filter.
BRG
Old 05-27-2011, 04:33 AM
bcovish
My Feedback: (8)
bcovish's Avatar
Pour a couple of ounces of it into a clear glass or jar and set it out in the sun. Will turn yellow if turbine oil has been added. If you have any kero that you know oil had not been added, do the same thing with the jar and set it beside the other jar, it should remain clear.
Old 05-27-2011, 05:52 AM
Kelly Rohrbach
Like said above,
Dump it and get new fresh fuel with oil and I bet you will sleep better, I know I would.
Old 05-27-2011, 06:07 AM
Ad Clark
Ad Clark's Avatar
Considering your investment of time and money I would treat yourself to some fresh fuel and a quart of turbine oil as others have already recommended-Your turbine beserves it!
Old 05-27-2011, 06:08 AM
BlueBus320
My Feedback: (57)
I vote "dump it". The risk far outweighs the benefit when price of turbine & jet considered.
Old 05-27-2011, 06:33 AM
hooker53
My Feedback: (106)
A little yellow? I thought Jet-A was a little dingy yellow??
Old 05-27-2011, 07:41 AM
John Redman
My Feedback: (8)
Or you could just add more oil (correct amount for the amount of fuel) and you will be fine. if the oil is in there, the extra won't hurt anything.
Old 05-27-2011, 08:59 AM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
I say set fire to it and see how dark the smoke is.... That will tell you if it has oil !!!!! Do it all at once !!!!
Danno
Old 05-27-2011, 10:56 AM
petera38
petera38's Avatar
Thanks for all the answers.
I´ll dumb it!
/Pete
Old 05-27-2011, 11:30 AM
invertmast
My Feedback: (23)
invertmast's Avatar
Jet A-1 actually has a straw-yellow color to it. It is not 100% water-clear, but the yellow-straw tint is very light.
Old 05-27-2011, 01:27 PM
fast jets
Your crazy for dumping it, put a small jar of it in the sun for a couple of hours and if it turns dark yellowish color it has oil in it. It is as easy to tell as night from day. Or do as John Redman sugests, add more oil it will never make any differance.
John
Old 05-27-2011, 01:31 PM
rctech2k7
rctech2k7's Avatar
ORIGINAL: petera38
Hi,
/Pete
Get a sample and dry it, it will leave oil or lubricant residue. Also the volume of Jet A in the container will help... Compare it with plain Jet-A.
Old 05-27-2011, 01:41 PM
ddennison
My Feedback: (15)
+1 on adding extra oil. I have done this once or twice when I couldnt remember!
Dave
Old 05-27-2011, 02:30 PM
gooseF22
gooseF22's Avatar
I have had kero break down, but it was 18 months old, but I would still dump it.. cheap insurance
Old 05-27-2011, 07:12 PM
telejojo
My jet (super bee) has been sitting since last summer should I get the fuel out of it or fly it?
Old 05-31-2011, 10:55 AM
rctech2k7
rctech2k7's Avatar
ORIGINAL: telejojo
For that length of time you should remove it and do preventive check... That is to make sure no obstruction, filters and clunks are in good condition. Settle it down and check if it's free from contamination then fill it back thru the filtered pump with suction clunk a little higher from the bottom.
Old 05-31-2011, 11:07 AM
rctech2k7
rctech2k7's Avatar
ORIGINAL: ddennison
Dave
Not bad to get an extra oil since it will turn into gas and burn, actually better compare with no lubricants at all.
Old 05-31-2011, 11:10 AM
highhorse
highhorse's Avatar
I KNOW that my memory is crappy, so I never, never, never buy fuel without pouring the oil into the container FIRST.
Besides ensuring a thorough mix job, I know that any fuel I have laying around already has oil in it.
Old 05-31-2011, 11:48 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
If you are worried about too much oil, add oil to this unkown 20 liters, and mix it with another 20 liters that you know is mixed right.
Old 05-31-2011, 04:19 PM
GSR
My Feedback: (145)
Same as Matt, I have done this in the past. Just add the proper amount or oil to the fuel in question and then parcel it out over the next few cans so the mixture is not that out of balance. Scotty
Old 06-01-2011, 01:22 AM
petera38
petera38's Avatar
I did a test with fuel containing oil and fuel of the suspected "No oil in fuel" type.
Poured 100 cc of each into a plastic jar and placed both in the sun. After one day they both showed smal sediment bubbles of "something" at the bottom, which I suppose is turbine oil? I didn´t notice any remarkable change of colour. However the suspected " no oil fuel" has been stored in a red plastic cannister, which is normally recommended for gas. I suspect the colour (yellow amber) might come from the cannister? It´s noticeably darker than my other fuel in spite using the same turbine oil. But different type cannisters.
Would you use it or dumb it?
/Pete
