Tamjets Gear Failsafe do work with gear door sequencer
Hi guys,
Few had problem not able to get the gear failsafe work with Jetronic gear door sequencer...
Here is how should be program.
1. Install the gear door sequencer and program it normal without gear failsafe hook up first.
2. Than install the gear failsafe between RX and gear door sequencer.
3. Go throught the same program as manual instructed.
Here is the catch where mistake can be make.
When you hit the gear switch prior to press the set button.
You had to wait for the gear door sequencer to finish it cycle before press the button.
This allow the gear door complete is sequencing.
If you had hit the button too soon..that cut of the pulse signal to the gear door sequencer.
That why is not working.
Hope that help.
Hope that help.
RE: Tamjets Gear Failsafe do work with gear door sequencer
Do you still need to run a signal amplifier before the Jetronic sequencer or does your gear failsafe eliminate the need for it?
