carf rookie with jc titan
TX
Hello,
Trying to find out some info on the rookie 2.....I'm having withdraws after crashing my kangaroo into a tree.....love that plane.
I have a jc titan at 34lbs thrust and want to try the crazy tumbling and hovering realm of jet and wondering will the titan fit in the rookie and what size fuel tank would give the best flight time.
Paul
Paul
RE: carf rookie with jc titan
Paul
I had one with a G Booster/Evojet 160 and two way Zimmermann vector unit, it had the glass carf tank at maximum size (3.2ltrs) and it gave 6 1/2 - 7 mins.
Watch out for tail heavy install and if you use the Alu wing tube add a wood insert as it flexes a lot without!
Dave
Dave
