Reload this Page >
Help! couldnt get my AMT 280 started today
Old 10-10-2011, 04:04 AM
G4guy
My Feedback: (13)
Default RE: Help! couldnt get my AMT 280 started today
Yes, that is correct.
Old 10-10-2011, 07:25 AM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Even my new olympus hp will keep running correctly if the egt probe fails. You will not be able to restart once you've shut down though. I have had egt probes fail on RAM's, PST's and on an old amt pegasus. The amt keeps running so you're not stuck with a deadstick landing like the others. Personally, I like that.
Old 10-10-2011, 03:38 PM
karl hibbs
karl hibbs's Avatar
I always thought it wasn't quite right the way they did the probe in the tailpipe
Old 10-10-2011, 03:47 PM
G4guy
My Feedback: (13)
ORIGINAL: karl hibbs
I have never had it come out, not after thousands of flights. It has always worked. Plus, I never have had an EGT probe fail. Thats in 2 mercury's, 1 Pegasus and 1 Olympus
Now, I have had the RPM Sensor wear out!!
Old 10-11-2011, 08:36 AM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
just put a slight bend in the probe in order to keep a slight amount of pressure and it won't pop out.
ORIGINAL: G4guy
Old 10-11-2011, 10:56 AM
  #31
Skycat66
Hi guys,
This is the answer on the EGT probe.
If the ECU is calibrated during start-up phase the EGT sensing can be set to monitor during running phase or not. Normally for RC it is set to the value that a disconnection of the EGT probe is accepted. This to avoid dead-stick landing due a incorrect EGT value.
After the turbine is cooled down, after flight, the EGT is needed for starting the turbine again.
Also RPM sensing can be set so it is not needed for flight. In this case the control uses time slopes for throttle up and down.
For a customer we now implemented (software version Vx30G) that if the RPM sensor is inactive and the EGT drops below a setpoint the pump is stopped.
All described above is for V2 ECU and software Vx30 and higher.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
