Reload this Page >
Skygate/CARF Viperjet
Old 08-08-2015, 10:08 AM
  #401
sportflya
My Feedback: (21)
Well guys we had a successful maiden. Zero trim 6min flights 12oz of nose weight at recommend cg. All throws are the recommended throw. What a winner!!!
Old 08-08-2015, 10:31 AM
  #402
sailing1
My Feedback: (134)
Congratulations. Love your color scheme. I am getting ready to add telemetry to mine mostly for the speed and altitude.
Old 08-14-2015, 12:03 PM
  #403
havard.j
Finally I got some nice shots in the air of my Viper.
It flies like a dream and the Merlin M200 provides short take off and realy good vertical
ID:	2114367   Click image for larger version
ID:	2114368   Click image for larger version
ID:	2114369   Click image for larger version
ID:	2114370   Click image for larger version
ID:	2114371   Click image for larger version
ID:	2114372   Click image for larger version
ID:	2114373   Click image for larger version
ID:	2114375   Click image for larger version
ID:	2114376   Click image for larger version
Old 08-14-2015, 06:20 PM
  #404
sailing1
My Feedback: (134)
Wow, great pictures.
Old 08-15-2015, 04:41 AM
  #405
paulhat
Agreed.. Amazing flying site you have there
Old 08-15-2015, 06:37 AM
  #406
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Absolutely beautiful flying field! Love the knife edge with the water fall and mountains in the back ground! Congrades on your Viper too!!
Old 08-16-2015, 11:03 AM
  #407
havard.j
Thanks guys
The airport is under Vinnu waterfall, the tallest waterfall in Europe and the sixth tallest in the world. The rc club has two hangars dedicated to rc planes.
Since we were flying in a narrow valley, it will be much vertical movement.
https://youtu.be/yl2IyCt8aWA
Name:	2015-08-13 20.09.17.jpg
ID:	2114705   Click image for larger version
Name:	2015-08-16 13.23.00.jpg
ID:	2114706   Click image for larger version
Name:	2015-08-16 13.26.07.jpg
Old 11-22-2015, 12:13 PM
  #408
Dave Wilshere
There is a growing number of Vipers in the UK. No1 sales man Big Geoff loves his P-160SX powered version.
ID:	2131868   Click image for larger version
ID:	2131869   Click image for larger version
ID:	2131870   Click image for larger version
ID:	2131871   Click image for larger version
ID:	2131872   Click image for larger version
ID:	2131873   Click image for larger version
ID:	2131874   Click image for larger version
Old 11-22-2015, 12:47 PM
  #409
Geoff White
Geoff White's Avatar
Yes, loving the model. Its the slow speed that everyone comments on.
Old 11-23-2015, 02:23 AM
  #410
skywarrior
skywarrior's Avatar
Default Like mine too
Just in case one needs attention I will always have one in my hangar.
Yes also,
I like mine a lot. It never feels that its going to bite you and flies rock steady all the way. ( with a little help from a Demon in my case )
If it can survive this then it says lots about the design and build of the C.A.R.F version. Mine has the 180 Rx
https://www.youtube.com/watch?v=niXx6xaBgFc
Photo courtesy of Dave Wilshere at RAF Wyton .Sadly no more flying there on a now housing estate
ID:	2132022   Click image for larger version
Old 11-24-2015, 11:53 AM
  #411
havard.j
Originally Posted by skywarrior View Post
Yes also,
Have you done any modifications on the wires to the Cortex Demon? I'm a little worried about using only two leads with power to it.
Old 11-24-2015, 04:31 PM
  #412
skywarrior
skywarrior's Avatar
Hi
Yes I have followed G White in supplying current to the servos via pos-neg then detaching the signal from the plug and connecting that in a separate plug into the Cortex.
This way the Cortex only supplies a signal and power comes direct from the Power box plug. In my case a competition SRS or on my second Viper a Royal.
I briefly talked to Demon at Jetpower and they said they were considering this for the future as well.
Regards
David
Old 01-01-2016, 06:02 PM
  #413
bluelevel
My Feedback: (39)
bluelevel's Avatar
Is there a reason why everybody moves the thrust tube so far backwards that it sits flush with the fiberglass tailcone? Wouldn't it be advised to move the turbine and thrust tube closer to the tank and slightly cut the fiberglass tailcone instead of adding useless nose weight?
Old 01-01-2016, 06:28 PM
  #414
sailing1
My Feedback: (134)
My pipe is mounted such that the pipe is about 1/2 inch inside the tail cone. Have the cone coated with some BVM heat shield on the inside but nave never noticed any heating of the cone. Power is from a Rhino. I also have my smoke tube coming out back of pipe.
Old 01-01-2016, 06:35 PM
  #415
bluelevel
My Feedback: (39)
bluelevel's Avatar
I am installing a pretty short turbine (Merlin 200) and if I move the thrust tube & turbine all the way forward so that the starter motor almost touches the back side of the tank, the thrust tube ends about 45mm (1 ¾ inches) inside the tail cone. My idea was to cut the tail cone slightly. This would move the CG further forward so that I would not need any nose weight.
Old 01-01-2016, 06:54 PM
  #416
lxfly
lxfly's Avatar
My tube is also mounted with about 3/4 inch inside, no problem with. Think you may cut 1 inch with no problem, Nevertheless I have more than 1 lbs of lead in my nose, but this is no problem for the Viper.
Old 01-02-2016, 06:07 AM
  #417
sailing1
My Feedback: (134)
Didn't need any lead in the front for my Viper. Have my flight packs plus ECU and Electric gear batteries up front. Had plenty of room so just went with larger batteries for ECU and Gear and balance worked out just fine. Plane has full smoke setup and weights 36 lbs dry (with full UAT).
Old 01-10-2016, 10:29 AM
  #418
vquick
My Feedback: (71)
vquick's Avatar
For the last month and half i been building my new Viper and this is some of the pictures of my building and I just finish last night the inside all i got left is install 2 servos Rudder and 1 aileron and finish the main gear door also i got a set of unilights i will be installing
ID:	2140683   Click image for larger version
ID:	2140684   Click image for larger version
ID:	2140685   Click image for larger version
ID:	2140686   Click image for larger version
ID:	2140687   Click image for larger version
ID:	2140688   Click image for larger version
ID:	2140689   Click image for larger version
ID:	2140691   Click image for larger version
ID:	2140692   Click image for larger version
ID:	2140693   Click image for larger version
ID:	2140694   Click image for larger version
ID:	2140695   Click image for larger version
ID:	2140696   Click image for larger version
ID:	2140697   Click image for larger version
ID:	2140699   Click image for larger version
ID:	2140700   Click image for larger version
ID:	2140701   Click image for larger version
ID:	2140702   Click image for larger version
ID:	2140703   Click image for larger version
ID:	2140704   Click image for larger version
ID:	2140705   Click image for larger version
Old 01-10-2016, 01:42 PM
  #419
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Hey Thomas! Didn't know you bought one! I looked at mine today to remember the mounting. I don't see any reason that you can't do it that way. You will only get about an extra inch forward. I am sure it will help eliminate some nose weight. Let me know when you are going to maiden, and I will come out to watch.
Old 01-10-2016, 02:32 PM
  #420
Dave Wilshere
Thomas.
Do you know where the balance is yet? Nose weight wise...
When you put it together please check the wheel/tyre clearance on both the fuselage and wing cut out, I've seen people miss this and have the main gear hang up as its jammed up.
It does not look like you sealed the woodwork at all before installation started? Smoke system and fuel you will end up with some oil in the fuselage at some time, untreated wood is like a sponge! Just a coat of finishing resin would have been enough.
Otherwise great job, neat builder.
Dave
Old 01-10-2016, 03:10 PM
  #421
bluelevel
My Feedback: (39)
bluelevel's Avatar
@Dan
I had it sitting in my garage boxed up for several months, just didn't have the time to start the build. But now she's coming together nicely. Probably 2 weeks and I should have her ready to maiden.
Thomas
Old 01-10-2016, 03:15 PM
  #422
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
@Dan
Thomas
Cool Beans!! I am looking forward to seeing more nice jets at CC. If you need to look at anything on mine, please ask, or any advice. I posted a lot of pictures earlier in this post to help. It is a fun and easy jet to fly.
With a 200, it should be pretty fast and unlimited vertical!! Are you adding an extra fuel tank? You have seen me dead stick mine, due to flying too long. I now have my timer to 6.5 minutes.
Old 01-10-2016, 04:55 PM
  #423
pfact
My Feedback: (92)
Thomas,
Can you post a picture of how you mounted the front pilot seat?
Phil
Old 01-10-2016, 06:24 PM
  #424
skywarrior
skywarrior's Avatar
Hi
As a matter of interest mine now balances at the rear of the main spar. Had 70 odd flights like this and its better for me than the other 60 at the front of the spar.
180 Rx with one 3 cell lipo half way up the side of the nose bay and two 5400 lipo's for Rx in front and as far forward of the nose wheel tire as possible. Lots of weight but it matters not to this plane it flies great and tracks like a train.
I also fly with one of the best UK fliers who also has this balance point. It has not let him down either.
Regards
David
Rt photo by Dave Wilshere / always liked this one David
ID:	2140812   Click image for larger version
Old 01-14-2016, 10:23 AM
  #425
bluelevel
My Feedback: (39)
bluelevel's Avatar
Below are a few pics of my build progress so far. I hope these might be helpful to others building the same plane.
The wings are done, I chose to go with the Behotec electric gear & brakes. Installation was pretty easy and straight forward. Stabs and rudder are also done, I am using Savox SV 1270 TG on all flying surfaces.
The Robart hinges for the front gear door are in, I also glued in an additional bulkhead in the front to hold the servo that actuates the gear door.
For the tank I chose to go with the bigger one from the large Hawk, I am pretty sure that my Merlin 200 will need the extra fuel capacity. I also glued a tray on top of the main tank to accomodate the smoke tank, which is actually a Flash wing tank.
The back of the plane is also completely wired & plumbed, the turbine and smoke tubes are installed. I moved the turbine as far forward as possible to save a little nose weight, this change required to shorten the exhaust nozzle a little.
Thomas
ID:	2141333   Click image for larger version
ID:	2141334   Click image for larger version
ID:	2141335   Click image for larger version
ID:	2141336   Click image for larger version
ID:	2141337   Click image for larger version
ID:	2141338   Click image for larger version
ID:	2141339   Click image for larger version
ID:	2141341   Click image for larger version
ID:	2141342   Click image for larger version
ID:	2141343   Click image for larger version
ID:	2141344   Click image for larger version
ID:	2141345   Click image for larger version
ID:	2141346   Click image for larger version
ID:	2141347   Click image for larger version
