Skygate/CARF Viperjet
#504
My Feedback: (54)
Nose heavy makes the jet/plane pull to the canopy in knife edge. He is just too slow for this jet. It is hard for a new jet pilot to get used the fact that a jet needs speed for lift. Coming from a 3D prop plane, there is a false lift that is created by prop's thrust. Jets don't have it.
#506
My Feedback: (39)
Phil,
I am a very accomplished pilot and sold my Viper because of its lack of aerobatic capabilities. The Viper has a stubby fuse and is very short coupled. Therefore it needs a lot of speed to knife edge properly. It's not just a challenge to do really sloooooooooooooooow rolls with this plane at or below half throttle, it is just plain impossible. The plane simply doesn't have enough rudder authority to do so! Just fly an Avanti, or Leonardo and you'll see the difference a longer fuselage makes.
Thomas
Thomas
#507
Question to all.
Having to use a lot of elevator on take off. Tried different flap settings up to 45 degrees with no substantial improvement.
Balance is at front edge of wing tube with 1/5th tank of fuel.
Using electron landing gear and had to remove 3/8" from length of nose leg to have clearance during retraction.
Think I might have to remove 3/8" from the mains?
Anyone using electron gear ?
Thoughts please.
Peter.
Thoughts please.
Peter.
#508
My Feedback: (54)
Negative angle of incidence on the ground during take off is forcing the jet to hug the ground. Faster the jet goes, the worse it gets. Should have just made a larger nose gear hole. Either buy a new nose strut and make a bigger hole, because if you reduce the mains by 3/8ths then you may have main retraction issues.
#509
With the nose gear mounted fully forward, it was still too long and interfered with a main former just aft of the hole.
Plenty of room to shorten the mains and still clear any obstructions.
#510
My Feedback: (134)
OK
My Viper uses Behotec C50 electric gear for the Mains and C40 for the nose. Also using the Behotec trailing link struts. Length of all gear was fine but did have to cut a small but of glass on the wing to allow fore the trailing link swing arm to fit. The gear is built like a tank and has worked great for 4 seasons.
Regarding elevator on takeoff, Sounds like it is nose heavy. Not really sure where mine is balanced but initially I balanced using the supplied Jig, center hole. Had to add some weight up front to get the recommended balance (with gear down, empty tank and full UAT). After about 10 flights I took all the weight out. I usually take off with full fuel and smoke tanks and use the stock takeoff flap setting. Rotation is smooth at about 1/2 throttle (45 lb Jet Central Rhino) and requires very little elevator to rotate.
#511
My Feedback: (54)
Good Morning Peter!
I don't think either one of us answered your question about the issues you are having with the Viper. I also thought others would have chimed in to help you. I would like to explain my thoughts and ask a couple questions.
First, I don't disagree with Sailing that you might be a little nose heavy, but not to the extent of the issue you are having on lift off. Once you remove the 1/5 of a tank of fuel, which is removing about a pound of ballast in front of the CG, moves the CG more towards the center of the tube. Balance is supposed to be performed with an empty main tank. In my experience, I don't think you are too noise heavy, and maybe where you need it to fly and feel comfortable. The reason that I believe it to be an incidence issue is for the following reasons. You bought a set of matched struts and retracts. The retracts, unless shimmed, don't change with the installation. They still give you a level playing field for the mounting of the struts. You took a matched set of struts and cut the nose strut 3/8's of an inch lowering the nose, which creates negative incidence. The fact that the nose strut doesn't fit makes me wonder if you weren't sold the wrong struts, or sent the wrong struts?
Please answer the following questions to help us figure your issue out. 1. When installing the main struts, did you have to enlarge the wheel wells in the fuselage for the wheels to retract into the wells? 2. With the jet sitting on the struts, power ON your transmitter, receiver and gear, provided you haven't changed your trims since you last flight. What is your elevator position? Is it in center? Or higher then center? If higher, by how much? 3. Do you have an incidence meter? If so, while the jet is on the gear, measure the incidence. I am sure it will show that you have a negative incidence. These questions will give you your answer. Please let us know. Thanks! Dan
#515
I had the opportunity to measure a stock set of landing gear and wheels on Sunday.
Calculations reveal a more favourable stance than first anticipated with my set up having .5mm lower on the mains relative to the nose than the stock set up.
Balance is at front of wing tube with 1/5 tank of fuel.
1- No modification required to fit mains.
2- Slight down elevator trim in flight mode.
3-Yes I do have an incidence meter, I will set it up tonight and take side view pictures.
Report to follow,
Thank you gentlemen,
Peter.
Report to follow,
Peter.
#516
My Feedback: (54)
Good Morning Peter!
Thank you for your answers. It is good that there is only a .5mm difference between stock gear. Still ashamed that you had to cut the nose strut. If you had to cut the fuse for the mains to fit, then your mains would have been too long. When you say: Slight down elevator in flight mode". Am I understanding gear up, flaps up? If so, then the down elevator is telling us that you aren't nose heavy, but rather tail heavy. IF you have a slight down elevator with flaps down, then this is normal. To me, it is still pointing at incidence. Also, when you do the incidence, fill the tank. This will add more weight on the nose strut to give you the worse possible measurement for the incidence at take off.
#517
Flight mode 1- Normal flight , Slight down elevator (Gear up, Flaps up) level flight 3/4 throttle setting.
Flight mode 2- Take off, Neutral elevator (Gear down , Flaps down tried 15 up to 40 degrees).
Flight mode 3-Landing, Down elevator 8 degrees (Gear down, Flaps 85 degrees).
Check incidence with full tank - Roger.
#518
My Feedback: (54)
From your Flight Modes, definitely incidence. You are actually a little tail heavy. Take off flaps above 25 degrees is actually adding more drag than lift. Also, the greater the flaps, the smaller the Angle of Attack until stall. This makes your flair in the landing more flat and more possible to land on the nose gear. Personally, I only use 30 degrees of landing flaps. Full scale usually don't go over 30 degrees, with some going to 40 degrees landing flap. Again, this is for the flair, drag to lift, and go around capabilities. Two other buddies that have Vipers at my field use a little more flap, but are starting to reduce the degrees. Also, as one of my buddies found out a couple weeks ago, the more flap you are using puts more strain on the servo with a higher chance of failure. He had a servo fail on downwind, and fortunately, he was high enough and got the flaps up after a hard roll. On short final, you would probably be done.
PS-Your P47 likes a lot of flap to get the two point landing. Again, so that you can land flat.
#524
My Feedback: (54)
What a brain teaser!!! All indications is that with 1.5 degrees nose up, not nose heavy, due to down trim in level flight, it should take off on it's own. Is this your first jet? The other thing that I can think of is too much expo. But, I am truly lost. Everything that we went through indicates nose down incidence. Level flight with down trim indicates tail heavy. What are you comparing this too as far as other jets that you have flown?
#525
I presently fly Boomerangs, Skymaster Hawk and this Viper.
Elevator expo is @ 35
Agreed - It should lift off or a least get light by itself.
Dave - the main wheel position is I believe in the only place it will fit and still retract up into the fuselage cut out.
Perhaps I am missing something in this regard?
