Reload this Page >
LMC Hawk MkII
LMC Hawk MkII
Old 10-29-2011, 12:22 PM
orbsah
Default LMC Hawk MkII
Hi all - I came across the subject kit at a garage sale and don't know much about this particular model. It's a NIB kit with a nice fiberglass fuse, pre-sheeted foam wings (48" span) and lots of hardware. Specs call for either a 40-60 glow front prop drive or ducted fan unit. I'm wondering if anyone has any knowledge of this kit and/or how they set it up (prop or DF) and/or how it flew. The picture of the assembled model came from google images, I have the kit. Thanks.
ID:	1680197   Click image for larger version
ID:	1680198   Click image for larger version
ID:	1680199   Click image for larger version
Old 10-29-2011, 01:29 PM
jason
jason's Avatar
Default RE: LMC Hawk MkII
There were a few of these Leicester Model Centre Hawks about during the late 80's / early 90's. Only ever seen prop versions fly.
Jason
Old 10-29-2011, 01:58 PM
Xairflyer
Xairflyer's Avatar
Had one with a 61 great flyer snag with small hawks is wing loading so a turbine setup might be a bit heavy for it
Old 06-10-2013, 03:17 AM
paulinfrance
Hi, i have recuperated a 1/2 built fuselage with half of a tailplane can anyone out there give me the dimensions and profile for the wing please, thanks Paul.
Old 06-10-2013, 03:26 AM
DominicM
DominicM's Avatar
Awesome. Prop jets are the future. [8D]
Old 06-10-2013, 07:42 AM
paulinfrance
The Future,,, Lol,, I have already built one Hawk with a .60 then their F 4 Phantom which i fitted a Rossi .60 rear exhaust, i also built the F 16 with an ops prop then one with a micro mould turbine, a super natty which i restored last year with an Irvine .53 which is probably one of the best planes that i have ever flown, The Mirage 2000 with a Rossi .40 and made a bigger wing to try out my Kit Built Wren 54 Mk 2 which is now in a Aviation desigh Rafale, and as i haven't much else to do after fitting in my new kitchen,,,,,, a quick Video of my Rafale,http://www.youtube.com/watch?v=P_ETHL8_1Cw
Old 06-11-2013, 10:00 AM
GrayUK
GrayUK's Avatar
The Thorpe Brothers did a conversion for this, you might try contacting them, they may have 'stuff' around.
It was never that good as a DF, not light enough. wing loading a bit high, but it did fly.
Paul G
Old 07-11-2013, 10:48 PM
paulinfrance
Most of the building is finished, i will try to post some pictures, i am having trouble finding the right plastic to mould the cockpit, the
moteur is an old OS .61 'max' Lander electric retracts and all flying tailplane,,,,,
Old 07-12-2013, 12:32 AM
SJN
Had one YEARS ago with a SC 46.......WAY underpowered, but it did fly solid
also had the F-4 Phantom with a webra 90.
Never god the performance I expected from it though.
ID:	1899702   Click image for larger version
ID:	1899703   Click image for larger version
ID:	1899704   Click image for larger version
ID:	1899705   Click image for larger version
ID:	1899706   Click image for larger version
ID:	1899707   Click image for larger version
ID:	1899708   Click image for larger version
ID:	1899710   Click image for larger version
ID:	1899711   Click image for larger version
ID:	1899712   Click image for larger version
Old 07-12-2013, 12:33 AM
SJN
last pics....
ID:	1899714   Click image for larger version
ID:	1899715   Click image for larger version
ID:	1899716   Click image for larger version
ID:	1899717   Click image for larger version
ID:	1899718   Click image for larger version
Old 07-16-2013, 08:54 AM
paulinfrance
WOW ! thanks for the pictures, while i was in paris this week end Without my 'toys' i was thinking about doing a Phantome after finishing my Hawk, if you still have it, can you do some measuring for me of the wings and tail plane, i have a mould of the fuselage, canopy and all the other bits but i have no idea of the shape, size and angles of the wings, can you help me please ?. thanks Paul,
ID:	1901120   Click image for larger version
Old 07-16-2013, 01:45 PM
SJN
sorry, sold them both quite a few years ago....
Old 07-17-2013, 05:00 AM
iiievolution
iiievolution's Avatar
Hello
I still have mine. What dimensions do you need exactly? Mine never flew it was too heavy and probably the Cyprus heat in summer didn't help eather. It was powered by a K&B 45 and turbax fan. I still have everything.
Paul
Old 07-17-2013, 11:22 AM
paulinfrance
Hi, nice to hear from you, NO way will it fly with a turbine, mine had a Rossi in the nose,,, What i need is everything, ie; span, main wing chord and thickness at the center, and angle, the same half way along where the 'end bits' go on, andthe 'end bits' again with their angles and of course the same again for the tail plane,,, and the balance point thanks Paul.
Old 07-17-2013, 11:56 AM
paulinfrance
If you can fill the measurements and angles in ?, thanks Paul
Old 07-18-2013, 06:10 AM
iiievolution
Hello
Just to make clear. It's the Hawk that I have. Not the F4
Old 07-19-2013, 10:31 AM
paulinfrance
Hi thanks, 'silly me',! i have nearly finished the Hawk i used a tryptique and some photos to work all of the measurements and angles, so now my next project is the F 4;
Old 07-22-2013, 07:59 AM
paulinfrance
Any one out there with some cockpit photos that i can print out and stick inside to make it look a bit better ?, after spending 2 hours on the internet all i found was these,,,,
