Reload this Page >
Skymaster F-15 question
Old 11-14-2011, 04:00 AM
WimB
WimB's Avatar
Default Skymaster F-15 question
I recently bought a used Skymaster F-15 with a as good as new Jetcat P-120 Sx in it (2hrs runtime)
I'm in the progress of doing a "D-check" on it, and while I'm at it, a M.L.U......
Now, I forgot to take a note on the neutral setting of the elevons, could someone who has the same plane point me in the right direction? should the TE of the elevons be in line with the pointed rear fuselage extensions when trimmed for level flight? this is the way I remember seeing it, but I noticed the elevons have a fairly positice incidence then....is this right?
Thx,
Wim
ID:	1686566   Click image for larger version
Old 11-14-2011, 04:11 AM
Pinnacle Aviation
Pinnacle Aviation's Avatar
Default RE: Skymaster F-15 question
Don’t you mean a 'structural 3C check combined with a CPCP check
Old 11-14-2011, 04:16 AM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
http://www3.towerhobbies.com/cgi-bin...P?I=LXET66&P=8
http://www.skymasterjet.com/arff15.htm
Old 11-14-2011, 04:23 AM
WimB
WimB's Avatar
whatever it's called, it's thorough!!!!! stripped it completely!
wim
Old 11-14-2011, 04:27 AM
WimB
WimB's Avatar
I've got that incidence meter, and i've downloaded the "manual", but from that it's not very clear what the neutral setting is....
thx anyhow,
Wim
Old 11-14-2011, 04:44 AM
DelGatoGrande
My Feedback: (23)
trim it up (from your incidence neutral) ,take of and then fine tune it
Old 11-14-2011, 03:42 PM
Hobby Inn
The bottom of my elevon at the end is even with the seam on the fuse.
Old 11-22-2011, 04:03 AM
WimB
WimB's Avatar
and balance & throws? as per instructions?
balance on the front "bridge" over the turbine?
elevator 50mm ans roll 35 mm? right?
Wim
Old 11-22-2011, 06:34 AM
KC36330
a CG slightly aft of recommended is much better IMO........ it's center of the forward wing tube. those settings for throws will fly it just fine, tweak them to your liking after flying it.
Old 11-22-2011, 04:21 PM
Hobby Inn
Specifications in directions work. Start there and adjust as needed.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
