New test and tune bench for Nano turbines from www.HAB.se
Thank you Martin, Henke - it was indeed the starter-motor slipping. I'veexperiencedthis with my Wren 54 before, but never the P20-SX.I'venow resolved it - thank you :-)<o></o>
This brings me on to however the problem I wasexperiencingbefore the starter-motor began slipping...<o></o>
The P20-SX goes through it’s normal start-up sequence, but the turbine never quite reaches the 85,000 RPM idle speed. If I’ve understood it right, only once the turbine reaches 85,000RPM is throttle control passed over to the throttle stick on the transmitter?<o></o>
During the start-up sequence the RPM reaches about 83,000 -> 84,000, but not quite 85,000 RPM. I eventually get the message AccTimOut and then -Cooling- even though the turbine is still running around 83,000 -> 84,000RPM. Also, once it reports AccTimOut/Cooling the throttle-kill switch on the transmitter doesn't do anything!? The only way I can kill the turbine is to pull the power!<o></o>
I certainly never experienced anything like this with my ECU before I damaged it and sent it back to JetCat for repair. Are there any settings with this repaired/replaced ECUI should be checking?
[youtube]http://www.youtube.com/watch?v=W9kT5mLtK6s[/youtube]
Mike
I have been told by JetCat and others that the P20 fuel pump sees the full voltage to the ECU at switch on, hence for the P20 it can not be used with a 3 cell A123.
Mike
Simply selecting the ‘Purge FuelSystem’ function via the DataTerminal sometimes works – sometimes doesn't. In this first video it does nothing!
[youtube]http://www.youtube.com/watch?v=wS7fDRZ2tx0[/youtube]
When it does work, if you hold down the ‘Change Value’ to active the ‘Purge FuelSystem’ function for more than around 3 seconds, the pump sticks on and cannot be turned off other than by removing the power. Once the fuel pump has stuck on, changing the fuel pump voltage/speed (either up or down) has no effect.
With hindsight, I actually witnessed the fuel pump sticking on in this way yesterday, but was unsure what was happening at the time.Yesterday I witnessed the turbine go into cooling mode (with the starter motor engaged), but the fuel pump was still running! The result was bellows of relentless white smoke as fuel was being pumped into a hot turbine.
[youtube]http://www.youtube.com/watch?v=tBbISsElTpk[/youtube]
i cant do nothing about this
either pump or ecu fails
Regards,
Martin.
Thanks Martin, My money is on the fuel pump this time... and they're not cheap :-(
Did you get the problem solved yet or still waiting for parts?
I've emailed JetCat in Germany but their tech-support (maybe the whole of JetCat) is away until the 7th January, so sadly I'm unlikely to get a response until then.
Mike
Each engine were let at the current state for some time for the temps to settle before takeing the snapshot.
The tailcone is way out of range for the FLIR (max 350°C) so it shows funny values.
.....................P20.........................................Kolibri T25
Idle
Idle
Full power
Full power
As I said previously the pump/bus sees the voltage plugged into the ECU when powering up, therefore I would think the Bus is toast, motor may still work, but without control, all seems to fit together with the posts above, hope you get this sorted.
Mike
We did some checks with the FLIR to see which trempratures we are looking at. Important when installing the engine in an aircraft, specially if made of foam. This is how it works, the FLIR gun presents the temprature that I aim at in the upper left corner of the picture. That's of course not the only value to read out. At the bottom of each picture there's a bar showing which color that indicates which temprature. Diffrent on all pictures so look closely and draw your own colclusions :-)
Wow! Amazing photos Henke!! :-)
So what is the technical reason that one runs hotter than the other, and is running hotter necessarily a bad thing?
<o></o>
<o></o>
The 'turbine conversion kit' for what?
It's for the Ready2fly Venom but will fit any 90mm EDF.
New ECU and new fuel pump - my P20-SX is now back and running on all cylinders again! Yippee!
New ECU and new fuel pump - my P20-SX is now back and running on allcylinders again! Yippee!
