Reload this Page >
Futaba S-BUS extension to PowerBox Competition SRS
Old 10-16-2012, 04:34 PM
wojtek
My Feedback: (73)
wojtek's Avatar
Default Futaba S-BUS extension to PowerBox Competition SRS
I am setting up a PowerBox Competition SRS with two Futaba FASST receivers. Each receiver connects to the Powerbox via a S-BUS cable. The S-BUS cables that came with the power box are 12" long. Is there any reason I should be concerned is I was to extend one of the receivers by another 24" ? This would be to my "redundant" receiver. This would be the only connection, and it would carry the signal to the Powerbox via the S-BUS, and also via this cable the PowerBox back powers the receiver ...
My inclination is to think that there should be no issue if I use twisted medium gauge extension ... any opinions to the contrary ?
thanks guys !
~V~
Old 10-16-2012, 04:53 PM
FenderBean
FenderBean's Avatar
Default RE: Futaba S-BUS extension to PowerBox Competition SRS
give it a try and just check your receiver strength and range check it should be fine
Old 10-16-2012, 06:34 PM
Aussie Bart
Aussie Bart's Avatar
There is no 'real' current flow down the Sbus cable only a data stream. Length of cable has no influence in our applications however I would suggest sticking with the twisted cable to ensure no outside RF interferance.
Old 10-16-2012, 07:55 PM
Carsten Groen
Carsten Groen's Avatar
woj, I asked pBox the same question and the answer was that it can be extended up to 3 meter.
Old 10-16-2012, 08:00 PM
wojtek
My Feedback: (73)
wojtek's Avatar
ORIGINAL: Carsten Groen
perfect thats what I was looking for ! ...
I know its only a data stream ( and back current to power RX ), however some systems may be more prone to having a signal affected when exceeding certain lengths ..
For the the 2nd RX is just a peace of mind anyway ( paranoia relief ) lol
~V~
Old 10-16-2012, 11:12 PM
Carsten Groen
Yup,
never can get too much safety
I'n my tomahawk Hawk I placed two R6203 receivers in optimum places along the fuselage, the cables are like 1.5 meter long, and works perfect.
The SBUS signal from the receivers are 3V signals, but the drivers are pretty strong and the data stream uses parity check so there is some (limited) check of the data received. The stream is also repeated every 16 mS, so it won't take long before another burst of (hopefully correct) data reaches the powerbox.
So just go ahead
Old 10-17-2012, 12:51 AM
schroedm
schroedm's Avatar
Futaba recommend a max of 5m with 3 - 3.5m being the most sensible 'long length'.
Rgds,
Marm
Old 10-17-2012, 10:13 AM
Xairflyer
Xairflyer's Avatar
I wouldnt class 3M long of one cable that controls half the jet sensible, I wonder how many extension leads most modellers will use there?
Old 10-17-2012, 10:17 AM
wojtek
My Feedback: (73)
wojtek's Avatar
ORIGINAL: Xairflyer
Im running the S.BUS cable from the RX only to a Powerbox SRS. I am not powering anything besides the RX itself via the connection. .. plus the long extension in my case would be only for the 2nd backup receiver.
As to your point however, this is why I think Futaba has S.bus junction boxes and power hubs ...
~V~
Old 01-23-2013, 02:21 AM
haisanjafri
haisanjafri's Avatar
Hi wojtek,
Can you attach a picture showing the directions of sbus connectors in receivers and slots being used for futher calrity? And there is a problem that servo leads slots in competition are of JR style wheres as I am using Futaba extensions and considering to trim Futaba male connectors to insert in the competition JR type female slots?
My setup is 18MZ, 2 x R7008SB recievers & PB Competition srs. And then I had a query that from which receiver transmitter shall show the telemetry feedback? From both may be?
How do you Bind both receivers with the transmitter?
A. One by one
Or
B. From Transmitter like Receiver A & Receiver B?
Query # 2
Which telemetry information Transmitter shall show on the screen? From Rx # 1? Or Rx # 2?
Query # 3
How do you map channels with both receivers which should be same of course
Old 01-23-2013, 02:40 AM
haisanjafri
Plus how to bind two receivers together? bind one by one by using single receiver mode in transmitter or bind one by one using dual receiver mode while both receiver in mode A? &from which receiver it shall show the telemetry figures?
Old 01-23-2013, 03:11 AM
mick15
mick15's Avatar
In the absence of Woj I can answer these questions for you.
The sBus connectors go into sBus8 connector of the Rx with the signal wire (grey) facing up.
The servo wires connect to the PB, with the PB held sBus connectors down all the servos are signal left.
The 7008 Rx 1 should be in 7+sBus mode ie press in your button then switch on power when green and red flash release button. The led should flash once in rotation press the button again, the led should flash twice in rotation, in this condition press the button for more than 2seconds, recycle the power. This is now RX 1 which when bound to the Tx will transmit all the telemetry. Telemetry is transmitted from sBus2 which is the horizontal port under sBus8.
Rx2 should have the same treatment except you will press the button three times resulting in four flashes in rotation, Rx2 is now in 9to16 channel mode 7+sBus, this can now be bound to the Tx as Rx2 but will not transmit telemetry.
You have probably realised you can only achieve 14 channels from the PB Comp, but by rearranging outputs you can get 16 by direct connection to the Rx for some channels.
m
Old 01-23-2013, 03:36 AM
haisanjafri
thanks mick! so as I have understood RX1 shall be in mode B and RX2 shall be in mode D?
Old 01-23-2013, 03:39 AM
haisanjafri
and obviously 18mz shall be in Dual receiver mode to bind both RXs
Old 01-23-2013, 03:42 AM
mick15
mick15's Avatar
That’s correct, PB are quite specific in that the PB should be driven from the sBus/8 connection and not sBus2.
m
Old 01-23-2013, 03:48 AM
haisanjafri
Sounds wonderful and perfect. thank you so much. now mapping is left in PB Comp srs, which I assume shall be not that difficult and may be more interesting. How about 2 Ailerons & 2 Elevators & Rudder+Nose wheel & 2 Flaps hooking into match channels to save channels? Or just simply connect separately?
Old 01-23-2013, 03:59 AM
mick15
mick15's Avatar
It is wonderful, be even better when Futaba give us an 18 channel PWM Rx!!
You have described exactly how it should be set up………….for the purposes of or CAA exemption certificate it states that each paired control should be driven from a separate RX and power supply, therefore Right aileron and right elevator must be driven from RX1 ie channel 1-8 and aileron and elevator Left are driven from Rx2 ie channel 9-16. To compliment this the PB has totally separate power supplies to each surface.
m
Old 01-23-2013, 04:03 AM
haisanjafri
So in case of match channels, can we reverse one of the two servos or shall have to use the slot outside the silver frame of match channels?
ID:	1843461   Click image for larger version
Old 01-23-2013, 04:11 AM
haisanjafri
& then one dirty thing. Can't insert futaba male connectors into SRS JR type female slots . Need to peel & trim the thin linefrom the futaba male connectors
Old 02-03-2013, 12:52 PM
haisanjafri
One question just being curious, can we connect both primary and secondary receivers both in B mode? Or it has to be Primary B and Secodnary D?
Old 02-10-2013, 11:29 PM
haisanjafri
Hey guys,
While using 18MZ + R7008SB receivers + TELEMETRY ON from transmitter, the frames losses on PB Competition from both receivers are like 900 & 1000. The moment I turned the TELEMETRY OFF frame losses came down to 5 Or 20 Or 25. Any comments?
Old 02-11-2013, 03:08 AM
Gonzalo38
Gonzalo38's Avatar
ORIGINAL: haisanjafri
Hey guys,
Have you seen any problems with this amount of losses ? ANy switching of the receivers ?
I'm about to install the Robbe/Futaba GPS in a couple of planes with the same configuration so I'm interested to know.
Old 02-11-2013, 04:05 AM
haisanjafri
The only problem I have been able to locate so far is
MORE FRAME LOSSES = While telemetry is ON
LESS OR ACCEPTABLEFRAME LOSSES = While telemetry is OFF
Shall apreciate more info on this from other users...
