Census of Hotspots !!!
#401
My Feedback: (49)
I have a new in the box never been started Graupner kit for sale. I don't see myself buidling it so its up for sale. Make me an [email protected] [email protected]. Pictures available upon request.
#404
Hey a question for you Hotspot guys. I crashed mine a few years ago from a really poorly timed engine failure. Still hurts, but I manager to pick up another kit!
All i have for power this time is a P180RX, which will be heavily de-tuned of coarse... When rolling back the max RPM, the fuel consumption typically suffers due to the lower pressure ratio in the engine. My 1st Hotspot had the ~2.5L main tank, with a pair of dubro 18 oz tanks in series on each side of it. (that made for ~3.5L) The pump was drawing from a UAT, then a DuBro, then the other DuBro, then the big tank in the middle. the big tank drained 1st.
It worked well, and kept from ballooning the big tank too much. I'm wondering though, what is the most fuel capacity that any of you have been able to cram into this jet?
Thx,
Kelly
Thx,
Kelly
#406
My Feedback: (49)
You seem to be suggesting that by running the engine at lower RPM the fuel consumption will go UP ? This is simply not true. If that was true the engine would burn the most fuel at idle and the least at full throttle. The specific fuel consumption for the power produced is probably less efficient and goes down but not the actual fuel consumption for a given period of time.
I have a Jet Tech kevlar tank in my Hotspot. 105 ounces made specifically for the Hot Spot $ 145.00. I know its enough capacity for a reasonable flight time, and would be even with a RXI 180, especially since you are going to turn the thrust down to that of a 140 or 120 or 100 .
Google search Jet Tech Fuel Tanks.
#407
I know about the jet tech. I have a few of them in other jets, good quality products... I was looking to see what configurations of tanks might have been tried, and what max fuel capacity might have been achieved. I might do the jet tech (3.1L), but I'd like to get 3.5L or better total.
Thx,
Kelly
#408
My Feedback: (10)
and it has a shocking amount of push for low speed vertical maneuvers. I would not limit the thrust but limit the speed.
I will say however the higher residual thrust is a very real problem. And of course dialing down the thrust does nothing for this so make sure you have very effective speed brake (including the push rod geometry) and I might recommend canting the rudders as well. I have not tried this on a hotspot but it is very effective on a stingray and even the bobcat.
#409
Matt, that's exactly the motivation I needed to hear!
I have no data what so ever on the 120SX I had vs the 180RX I have now, but I'm a huge fan of the vertical takeoff. The 120SX had enough push to sustain straight up with full fuel, right from liftoff. I can't wait to see the next on 'accelerate' up... I need to get myself a speed sensor!
I ran 4 different engines on that hotspot in the 10 years I flew it. One was horrendous on fuel, so it got me a bit gun shy on flight time. The same engine also had a high residual, making the landings very tricky. The 120SX was pretty good, my favorite of the 4 engines by a long shot. If I were doing it again, I'd do a 140.
Good call on the speed brake options. With the inward leaning fins it might make sense to deflect the rudders inwards to counteract a nose up moment. Won't know till I try it...
Thx,
Kelly W
Thx,
Kelly W
#410
Hi,
I have a two servo per wing setup. Can you tell me
Movement up
Movement down
Are movements same per wing i.e. outboard and inboard surfaces move by same amount
Any reflex
Any braking i.e. CROW and if so movements
Paul
Movement up
Movement down
Any reflex
Paul
#411
My experience with underrating turbines is very different, but it might be also due to the engines used.
I have a velox XL, which has been flying for a few years with a k180 detuned to about 12~13 kg of thrust. This year I took it out to put it into a bigger plane and replaced it with a k120 and the fuel consumption went down VERY noticeably, while the power of the airplane is very comparable (the 180 had a much better low rpm push and spools faster, but that's about it). I suppose the k120 is an overall more efficient engine than the k180, but anyways, this is what I experienced
I went as far as removing one of the 3 tanks and only filling up the second tank up to half this season.
#412
My Feedback: (10)
Yes it whould be worth experimenting, I had inward canting on the stingray and outward on the Bobcat.
On one bobcat I had, I carefully set up the rudders with big servos and a lot of throw. When I threw them out it was like slamming the brakes in a car, far too effective!
I think you will be pleasantly suprised. The canting rudders, good speed brake, wheel brakes you can preset on landing and keep that P-180 at full tilt, should be fun
#413
Having previously got my hotspot down to 7kg dry (to be able to fly at my local field), i discovered that even with a VT80, it could fly indefinately on idle power. Landing it became a problem as it was too slippy and the runway was too short. After a few mishaps with fast landings i decided to abandon the 7kg limit of our local site and fly elsewhere. This meant i could now add an airbrake, wheelbrakes and add redundancy in the power supply and beef up the turbine battery.
Having painted the fus, burying the airbrake outine cast into the surface, i was pleasd to find i could see the shape using a bright led torch from the inside. My brake uses a servo that latches by virtue of an inline linkage. I have also added a pair of magnets to grip the airbrake when fully shut (magnets close but not touching) to stop the digital servo "singing".
fury91 (12-30-2021)
#414
My Feedback: (18)
Hello friends:
I build another Hotspot (my 3rd) and I would like to know how much Hotspots there are in flight ???
Please put photos !!!
BR from Spain.
Carlos Márquez
___________________________________
Blog de Carlos Márquez
BR from Spain.
Carlos Márquez
Sorry to change the subject, but that is a nice F-18 in the background. Who makes that one and what scale is it?
sc
#417
Come back to Hotspot, I'm installing Electron Retracts, the best landing gears in the market. In sort photos !!!
i'm anxious for see the result !!!! and fly it, of course.
i will make a new tank too, my Hot has the nose heavy because it's painted, I think this is reason, and not has logical install a tank that is all in front CG, and of course, will be available in CMJETS Website.
and ...... the next month at last, the new Hotspot fuselage ready for molds !!!!!!
Regard from Spain
Carlos
www.cmjets.com
Regard from Spain
Carlos
www.cmjets.com
#419
Hello, the new Hotspot project go slow that I want, I have too much job with my tanks and I not begin the molds yet.
in short, I hope, I will have it. As soon I have it, I will show it here, sure.
i have my actually Hot with Electron and go superb,
I will try upload pictures.
Thanks for contact.
Carlos
www.cmjets.con
Thanks for contact.
Carlos
www.cmjets.con
#420
My Feedback: (49)
Ok Hotspot experts I need some balance help. I need to know the correct procedure and range for Center of Gravity. I presume it is done with gear down and fuel tank empty ? 7 to 7.5 inches outside of the vertical fins. Is any one flying with CG less than 7 inches or greater than 7.5 inches outside of the verticals. I am having some troubles getting my cg that far aft even with batteries all the way aft.
#421
My Feedback: (38)
Going by memory, it's been awhile, measure down the leading edge about 6inches from the root. Should end up about 1.5 to 2in. In front of main landing gear. Not super critical with the hot spot. If you need more tail weight, move the engine back a little.
#422
My Feedback: (49)
The hotspot instructions call for 7 to 7.5 inches. They do not say if that is with empty fuel tank (which is the norm) and with gear up or down. I imagine it is with gear down and no fuel.
#424
Hi All, the this post is stop !!! What happen with the Hotspot lovers ???
My Hotspot is amazing, each time I love it more.
My deceased father pose with it, I will miss you, dad.
show your Hotspot pictures !!!
BR from Spain
Carlos
#425
Hi Hotspot lovers !!!!
The new master of Hot is almost ready for molds, I will make the speed Brake and landings wells in the molds, I hope you like it.
at the moment some pictures of big hatch, the speed brake will be in the hatch with a MPX conector !!!
